Spark plug gap?
Old Nov 15, 2009 | 05:59 PM
Black_Turbo_SS's Avatar
Spark plug gap?
I bought spark plugs from autozone. The computer said they should be gapped to .043. How Dow that sound. Car is moded and tuned as well?
Old Nov 15, 2009 | 06:03 PM
slowbalt84's Avatar
no no no no no. .032-.035
Old Nov 15, 2009 | 06:29 PM
glhs379's Avatar
did mine at .32
Old Nov 15, 2009 | 06:30 PM
slowbalt84's Avatar
^ me too. Did you use autolite iridiums also?
Old Nov 15, 2009 | 06:33 PM
Zander916's Avatar
I've experimented with this quite a bit. Just wanted to see what was what...
Figured out that it's best to just leave them alone. I have the stockers and set to .032. Seems to be the best.
Higher than around .035 seems to provoke misfire and smaller than .032 starts to eat at the throttle response.
Old Nov 15, 2009 | 06:34 PM
ff_drift_lol's Avatar
mitchell says .40 max, alldata says .35 max. could be wrong it is mitchell on demand. I have been gapping mine to .35 and no problems.
good info!
Last edited by ff_drift_lol; Nov 15, 2009 at 06:34 PM. Reason: Automerged Doublepost
Old Nov 15, 2009 | 06:40 PM
slowbalt84's Avatar
i actually went to .030 in the beginning because i thought that was the right gap. Found out it was .032-.035 so i pulled them out and changed them to .032 although they seemed exactly the same as .030 so i dunno. just outta curiousity does it benefit going to a smaller gap?
Old Nov 15, 2009 | 06:42 PM
Maven's Avatar
factory spec is .030-.035" Autolites arent a good choice for GM vehicles. ACDelco, NGK, Denso, Beru are the only plugs I ever use in GM vehicles.
Old Nov 15, 2009 | 06:45 PM
http://www.ngksparkplugs.com/tech_su...lugs/index.asp <very useful
Old Nov 15, 2009 | 06:48 PM
JPizzle's Avatar
Very good info!
Old Nov 15, 2009 | 06:51 PM
Rage915's Avatar
i went .32 on mine
Old Nov 15, 2009 | 06:58 PM
slowbalt84's Avatar
why aren't they a good choice? they've been in for a little over 1000 miles gapped to .032 and i just pulled them and they look good and everything runs fine.
and i know that quite a few people are here are running them with no problems
Last edited by slowbalt84; Nov 15, 2009 at 06:58 PM. Reason: Automerged Doublepost
Old Nov 15, 2009 | 07:01 PM
for example: chrysler loves champion spark plugs. GM just happens to like NGK and of course acdelco. if I used champion's on my cobalt there'd be problems. I'm not sure of the technical aspect but this is what I've gathered doing tune ups for so many years.
Old Nov 15, 2009 | 07:11 PM
Ok. Thanks
Old Nov 15, 2009 | 07:26 PM
slowbalt84's Avatar
ok but i have no knock or misfires or any loss of performance or anything bad from the autolites and i don't think anyone else that uses them on this forum has had any problems
Old Nov 15, 2009 | 07:31 PM
I think maven was just giving you some advice that's all. I would switch over next tune up, or if you're really satisfied do what you want. it's your car.
Old Oct 5, 2011 | 09:43 AM
vahdyx's Avatar
I did a search and this was the best result I could find to answer my question.
I set my gap to .029 and it's running like a champion! With my Aeroforce Gauges, I no longer get random KR at .7-2.9 degrees and my false-positive misfire readings (no official misfire/No CEL) have dropped down significantly.
Vince recommended I go to .028 due to my altitude, but who knows. All I can say is my experience since yesterday (October 4, 2011) has been good so far. I'll keep an eye out, but I'd love to hear your expertise on why this may be bad or beneficial with the mods in my sig!
Old Oct 7, 2011 | 12:28 AM
Knightwolf's Avatar
Factory spec is either .040 or .035, I forget, but it depends on your tune/mods and probably your elevation. I'm currently running 1 step colder at .032.. some ppl run .030 or even .029.. depends what works best for you and your application.
Old Oct 7, 2011 | 10:46 AM
BYT*SS*TURBO's Avatar
Factory is AC Delco 41-108 Plugs at .035 Gap. I just bought 2 new sets and they seemed to be .032 out of the box. I left them there.
Old Oct 7, 2011 | 10:48 AM
BartSS's Avatar
Im at .32 on my 3787s
Old Oct 13, 2011 | 10:39 AM
tlanzetta11's Avatar
When everyone says they gap it at lets say .032" is that the same when others say .32"?
Old Oct 13, 2011 | 10:45 AM
nutty21's Avatar
Yes
Old Oct 13, 2011 | 10:51 AM
nutty21's Avatar
I thought oem were ILTR5D?
Old Oct 13, 2011 | 11:12 AM
emiller's Avatar
That's the nkg part number. It's the exact same plug.
Old Oct 13, 2011 | 11:30 AM
Yes
Appreciate it!
