Spark plug gap?
Old Oct 13, 2011 | 12:04 PM
JshLnsctt's Avatar
What are NGK's gaped to out of the box, can they just be left alone safely?
Old Oct 13, 2011 | 12:20 PM
emiller's Avatar
.035 same as the 41-108 since its the same plug.
Old Oct 13, 2011 | 06:02 PM
FasterIsBetter's Avatar
Originally Posted by BYT*SS*TURBO
Factory is AC Delco 41-108 Plugs at .035 Gap. I just bought 2 new sets and they seemed to be .032 out of the box. I left them there.
Yep, they seem to be gapped perfectly for the LNF right out of the box. I noticed the same thing when I went to gap mine as well. I thought it was a lil closer to the .030 mark but thats what I get for using a spark plug gapper to check the measurement. Shoulda pulled out the feeler gauge.
Old Oct 13, 2011 | 10:46 PM
brant's Avatar
depends on mods.. im 0.024
Old Oct 14, 2011 | 01:25 PM
VR09Sedan's Avatar
I just bout 41-108 from O Reilly and they came .030 out of the box, so I regapped them to .035 . Regapping was a PITA. I'm on stock tune no mods.
Old Oct 16, 2011 | 12:57 AM
Ch1ck3n's Avatar
Stock plug. Stock gap. Doit
Old Oct 16, 2011 | 01:46 PM
CrystalRedSS's Avatar
when you change spark plugs do you have to torque them to a certain ft/lb?
Old Oct 16, 2011 | 01:53 PM
kikal8's Avatar
Originally Posted by slowbalt84
i actually went to .030 in the beginning because i thought that was the right gap. Found out it was .032-.035 so i pulled them out and changed them to .032 although they seemed exactly the same as .030 so i dunno. just outta curiousity does it benefit going to a smaller gap?
no. larger gap creates more power. larger spark is more power. but like someone said. gap to much and u get misfires.
Old Oct 17, 2011 | 01:47 PM
VR09Sedan's Avatar
Yep
I don't know the ft/lbs off the top of my head. I measured the resistance as I took them out and went off that. Not the recommended way, just don't overtighten them or it's big bucks to get them changed the next time. I also used dielectric grease in the coil pack & on non coil side of spark plug to help with corrosion. Went off a post I found on this site
Old Oct 17, 2011 | 02:02 PM
Wangspeed's Avatar
15 ftlbs
Old Jan 8, 2013 | 04:02 PM
  #36
BlueDemon's Avatar
Something to keep in mind guys, .032 and .32 is not the same thing. If you see a two digit spark gap measurement, that is Metric. Three digit refers to Standard. Pay close attention, it's very easy to get confused. So... .032" actually is equal to .88mm (may be why so many people have idle issues, everyones getting mixed up in standard and metric.)
Old Jan 9, 2013 | 03:24 AM
  #37
Nfamous60's Avatar
^^^^this mine are gapped at .030
Old Jan 9, 2013 | 03:45 AM
  #38
nwss's Avatar
gapped all mine differently...034 .033 .032 .031
because brobalt
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
