Spark plug indexing
Spark plug indexing
I haven't seen anyone post about spark plug indexing on here. Just wondering if anyone, probably tuners mostly, have noted any gains from indexing the spark plugs.
For those that don't know, this practice is facing the opening were the electrode and tip meet towards the intake, providing a clearer path the the air fuel mixture.
That being said I understand the the fuel isn't mixed in the intake but the injectors do point in the same direction as the intake. we know this works for marginal gains, but gains none the less in pfi applications, so I was just wondering about Di applications, thanks!
Theoretically, the mixture is so fine and well dispersed, and the bowl it sprays into in the piston is shaped around the plug, any gains you get should be almost too small to measure. The whole point of DI is more efficient combustion, so the other methods we used to get maxed efficiency are all diminished slightly.
Try some back to back dyno pulls and see what happens, i'd bet there would be no measurable difference on an LNF.
agentirons
Oct 16, 2015 02:11 AM
