Electronic Boost Controller Help
Old Apr 12, 2015 | 05:46 PM
Teetzel's Avatar
Im looking to buy an A-Pillar from ZZP with the extra two gauge pods, along with my RPD. I planned to put an interceptor gauge and the AEM truBoost controller in. Who has experience with either of these gauges, and what are your opinions on them?
I really don't know much about boost controllers, and generally just go to ZZP and browse and when I have questions on something, ask them here.
\Thanks!
Old Apr 12, 2015 | 06:05 PM
Sl0wbaltSS's Avatar
You can get the coupe triple gauge pod, the sedan a pillar and the rpd, do some magic with DIY stuff and you can have the RPD on the sedan. A member on here has made his own a pillar and had the RPD work with the sedan A pillar. Boost controllers or boost gauge? You don't need a boost controller but you can use the boost gauge in the rpd.
Old Apr 12, 2015 | 06:23 PM
kzak104's Avatar
i have dual interceptors and theyre great, no complaints, as for boost controls ive installed a couple true boost controlers and they are easy to install and operate, straight forward and out of the way in a guage pod, also acts as a vacuum and boost guage.
Old Apr 12, 2015 | 07:02 PM
Teetzel's Avatar
so i do or dont need a boost controller? cause if i dont ill go with the dual interceptor gauges. not sdure what else i could throw in there. I like the way 2 gauges and the RPD looks though.
Old Apr 12, 2015 | 07:14 PM
63 Nova SS's Avatar
If you have an lnf you don't need one. Boost controller is in your computer.
Old Apr 12, 2015 | 07:48 PM
Teetzel's Avatar
ok thanks!
Old Apr 12, 2015 | 08:05 PM
kzak104's Avatar
to control boost with the ecu youll have to flash a new low or high boost tune when you want to change it, cant change on the fly unless you have trifecta.
Old Apr 12, 2015 | 10:34 PM
tomj77's Avatar
Yup listen to these guy, if u just go adjusting the boost with a controller ur gonna break ur engine. I have a solenoid failsafe boost control, when meth stops boost is cut in half. But that's not for driving around in, just to save my motor
Old Apr 12, 2015 | 10:50 PM
kzak104's Avatar
i hear you tune for high boost then turn it down not the other way around? never used a boost controller on my own car tho,
i went the long rout, low boost tune for auto x and track and high boost for other uses
turbochargedss2012
Sep 20, 2023 12:17 PM
DocSvensk
Sep 27, 2015 02:24 PM
Coballin13
Sep 25, 2015 08:43 AM
