Squeak noise
Old Oct 18, 2015 | 06:57 PM
Gugi96's Avatar
Squeak noise
My old rotors and pads were **** so i bought new powerstop z23 evolution sport drilled and slotted brake kits front and rear. Me and my brother did it together we made sure everything was correct and lubed up really good. But for some they squeal soooooo loud when theyre cold, its not bad after they warm up and i brake slowly and when i do a hard turn or enter a steep angled driveway. I have really bad sway bar end links and control arms. I think they make noise too but only if its cold and or i enter a steep angled driveway. Everytime i fix a problem another pops up
Old Oct 18, 2015 | 07:02 PM
tomj77's Avatar
Did u grease the back of the pad where the piston pushes? Other than that, performance pads sqeek usually.
Old Oct 18, 2015 | 07:13 PM
double clutch's Avatar
Did you spray the rotors with brake clean to get rid of the protective coating before the install? That will cause squeaking.
Old Oct 18, 2015 | 07:28 PM
Gugi96's Avatar
yes,everything possible is lubed except the rotors and the side of brake pads that contact the rotor
Gugi96's Avatar
no ill try that thanks
Old Oct 18, 2015 | 09:46 PM
Probably not going to do anything now. The brake pads ground the film off and it is most likely now embedded into the pads
Old Oct 19, 2015 | 12:21 AM
Gugi96's Avatar
That sucks
tomj77
Dec 22, 2015 07:03 PM
BeginLoL
Oct 13, 2015 10:25 PM
roth
Sep 26, 2015 12:16 PM
umrdyldo
Sep 21, 2015 05:28 PM
jrsmith
Sep 20, 2015 07:17 PM
