Stage Tuning coming
Old Dec 31, 2008 | 11:27 AM
Psykostevo's Avatar
Stage Tuning coming
I will have my hands on the new OS and the new sensors in the next couple days. I will be doing preliminary testing to see what the kit does "As-is" and what it will do after my hands get on it.
What I saw posted in the other thread about ADM's results was not what was expected of this kit. Maybe the kit doesn't deliver the 18-19 psi that was promised, looks more like 22 psi to me, but I have not seen it first hand.
I will be testing this kit on a local car here, and obviously sharing the dyno results compared to stock, and then compared to after my revisions.
Something has to be done about this kit, and it needs to get onto some Cobalts!
Old Dec 31, 2008 | 11:28 AM
GTPprix's Avatar
Hrmm last I checked its the same OS just calibration data changes, sneaky sneaky! Can't wait to see your results!
Old Dec 31, 2008 | 11:31 AM
supermantxz24's Avatar
i cant wait to see the numbers you put down good luck sir
Old Dec 31, 2008 | 11:34 AM
Psykostevo's Avatar
How could they calibrate a 3 bar sensor on a 2.5 bar table without changing the OS?
Old Dec 31, 2008 | 11:56 AM
Terminator2's Avatar
They had to have, but I heard somewhere that the desired airload tables were the same as stock. Is that possible?
GTPprix's Avatar
Well the two stage files I've seen have the same OS as the regular LNF (would explain how HPT had support as well) Bosch stuff is wierd, they dont operate the way conventional E series controllers do. Who knows, I just want to see how you make out!
Old Dec 31, 2008 | 12:01 PM
The sensors just have a greater pressure range maybe they are calibrated the same as stock. That would definately explain why ADM was able to tune their HHR with HP tuners already.
Old Dec 31, 2008 | 12:29 PM
Psykostevo's Avatar
Yeah, did they do a full retune, or just load the GM Stage file? Or did they do both?
Old Dec 31, 2008 | 12:30 PM
GTPprix's Avatar
Both last I saw, like I said Bosch controllers especially the MED9 family do things VERY differently than the E/Legacy controllers we are used to
Old Dec 31, 2008 | 12:38 PM
Thay did both. They made 297 whp 354 wtrq with stock GM tune with intercooler, exhaust and downpipe. Then they modded the tune and made 332 whp and 395 wtrq. As I understand it the modded pull was made on 100+ octance and probably 24-26 psi. The Hp and torque really drop off up high though.
Someone needs to make cams for the LNF. Nothing too agressive but that would increase VE and hopefully top end Hp and torque after 5500RPM to until past 6300 RPM.
Old Dec 31, 2008 | 12:55 PM
Psykostevo's Avatar
Or someone other than me can learn how to tune cams like me, and then the power doesn't fall off up there.
Old Dec 31, 2008 | 12:58 PM
Greased's Avatar
or you can get a new turbo that is fit to produce more power lol
Old Dec 31, 2008 | 12:59 PM
Psykostevo's Avatar
No way!
Old Dec 31, 2008 | 01:01 PM
1BADSS/SC's Avatar
+1
Synapse maybe? Just a guess. U guys can have my TD05 when Im done with it
Old Dec 31, 2008 | 01:16 PM
Psykostevo's Avatar
Originally Posted by SUKXOST
my 09 TC PCM (sent to Hahn for tuning-sorry Stevo) was never seen by HPT before. Hahn had to get ahold of HPT as something was different in my calibration. No telling what ur gonna get with a new car these days. :P Good luck with all of this Stevo...I'm sure you will get awesome results.
I came across that yesterday too with an 09 cobalt. It gave me an error that I had never seen before.
So when are you going to put on a black spoiler? It would look awesome with a black spoiler, leaving the uprights white.
Old Dec 31, 2008 | 01:31 PM
Of yeah, I forgot that you can tune the stock cams with HP tuners, But if you are running more than 23 psi you will be getting well outside the stock turbo's efficiency range at the upper rpms. Retiming the cams will definately help though.
Old Dec 31, 2008 | 01:39 PM
SUKXOST's Avatar
So when are you going to put on a black spoiler? It would look awesome with a black spoiler, leaving the uprights white.[/QUOTE]
I suppose when I can find one for a good price :P
Old Dec 31, 2008 | 01:45 PM
Area47's Avatar
Rent me! per hour
the stage tune has made changes to the tables not given to us hpt. it's that simple.
Old Dec 31, 2008 | 01:53 PM
08BlackSS/TC's Avatar
yes, tables that HPT still can't seem to figure out for some reason
Old Dec 31, 2008 | 01:56 PM
Psykostevo's Avatar
We shall see if they redefine them for us so we can see them. That way we don't have to buy stage tunes from GM. It would be nice.
Not that they can't figure them out, but that they don't think all tuners should have access too. They try to give you what you need, if they gave you access to everything then want to be tuners would just change everything just because you can.
Last edited by Psykostevo; Dec 31, 2008 at 01:56 PM. Reason: Automerged Doublepost
Old Dec 31, 2008 | 01:58 PM
boostking's Avatar
true true.
Old Dec 31, 2008 | 02:00 PM
Well then that's their fault if something goes wrong
Old Dec 31, 2008 | 02:02 PM
boostking's Avatar
f*ck it lets call AEM up and get some EMS's
Old Dec 31, 2008 | 02:51 PM
PimpLay2's Avatar
dont mean to thread jack
but how good are you with tuning a 08 mustang gt
my buddy has one and im sure he would like 1 pm with details im sure your all ready booked with them
Old Dec 31, 2008 | 03:11 PM
idlingmike's Avatar
You're joking right?
