Stainless steel brake line install?
Just starting installing this kit and noticed the front banjo bolts included with the kit are not the same thread or size as the stock one... It's from THM and it says 08+ cobalt on the bag they came in..
Are these supposed to just screw right in no problems or what?
all s/c and t/c caliper banjo bolts are the same/thread/dimension. dont use the ones that came with the kit if they are not correct. You must use new crushwashers, but verify the banjo bolts you have from your car fit correctly in the stainless lines,otherwise, dont use them if the banjo on the lines is much larger than the diameter of your existing banjo bolt. good luck.
New crushwashers every time ! lol.
Maven says and I quote, PAY ATTENTION TO THE LAST LINE!!
"Delta Brake Torque Specs
Brake Caliper Bleeder Valve - Front With RPO LNF
14 N·m
124 lb in
Brake Caliper Bleeder Valve - Front Without RPO LNF
11 N·m
97 lb in
Brake Caliper Bleeder Valve - Rear
11 N·m
97 lb in
Brake Caliper Bolt - With RPO LNF
130 N·m
96 lb ft
Brake Caliper Bracket Bolt
115 N·m
85 lb ft
Brake Caliper Guide Pin Bolt
34 N·m
25 lb ft
Brake Hose Fitting Bolt - Front With RPO LNF
40 N·m
30 lb ft
Brake Hose Fitting Bolt - Front Without RPO LNF
48 N·m
35 lb ft
Brake Hose Fitting Bolt - Rear
48 N·m
35 lb ft
I put red loctite(272, etc) on all of these bolts except the bleeder screw and the bolts/banjo bolt for the brake hose. Overkill? yeah. But brakes falling off sucks. "
Does anyone know what the part# is for the stock front brake lines? I looked on gmpartsdirect.com and they do have a listing for a "flex hose", but it does not give much info like left or right.
