Stainless steel brake line install?
Old Dec 15, 2012 | 08:35 PM
JAYNO20's Avatar
Just starting installing this kit and noticed the front banjo bolts included with the kit are not the same thread or size as the stock one... It's from THM and it says 08+ cobalt on the bag they came in..
Are these supposed to just screw right in no problems or what?
Old Dec 15, 2012 | 08:41 PM
Omnigear's Avatar
There are different threads for different years not sure which is which
Old Dec 15, 2012 | 08:59 PM
Powell Race Parts's Avatar
all s/c and t/c caliper banjo bolts are the same/thread/dimension. dont use the ones that came with the kit if they are not correct. You must use new crushwashers, but verify the banjo bolts you have from your car fit correctly in the stainless lines,otherwise, dont use them if the banjo on the lines is much larger than the diameter of your existing banjo bolt. good luck.
Old Dec 15, 2012 | 09:14 PM
^^so ur saying these lines should work on any year ss correct? been thinking about getting a set
Old Dec 15, 2012 | 09:15 PM
JAYNO20's Avatar
Just another issue with this order from THM... I guess I am reusing old bolts. Hopefully it works out ok. Thanks for your help guys!
Old Dec 15, 2012 | 09:28 PM
I dont know I have not seen them, I am addressing the issues of banjo bolts being different. The Turbo Cobalt with Brembo's has a longer front brake line, so if you get the right brake line, having it longer for the supercharged cars will be okay. At Ride Height, make sure that when you turn the car's front wheel fully out, it doesnt stretch the brake line, and when you turn fully in, make sure the line doesnt rub against the wheel/tire. You will be golden if its all good.
New crushwashers every time ! lol.
Maven says and I quote, PAY ATTENTION TO THE LAST LINE!!
"Delta Brake Torque Specs
Brake Caliper Bleeder Valve - Front With RPO LNF
14 N·m
124 lb in
Brake Caliper Bleeder Valve - Front Without RPO LNF
11 N·m
97 lb in
Brake Caliper Bleeder Valve - Rear
11 N·m
97 lb in
Brake Caliper Bolt - With RPO LNF
130 N·m
96 lb ft
Brake Caliper Bracket Bolt
115 N·m
85 lb ft
Brake Caliper Guide Pin Bolt
34 N·m
25 lb ft
Brake Hose Fitting Bolt - Front With RPO LNF
40 N·m
30 lb ft
Brake Hose Fitting Bolt - Front Without RPO LNF
48 N·m
35 lb ft
Brake Hose Fitting Bolt - Rear
48 N·m
35 lb ft
I put red loctite(272, etc) on all of these bolts except the bleeder screw and the bolts/banjo bolt for the brake hose. Overkill? yeah. But brakes falling off sucks. "
Old Dec 17, 2012 | 04:46 PM
Neodous's Avatar
Does anyone know what the part# is for the stock front brake lines? I looked on gmpartsdirect.com and they do have a listing for a "flex hose", but it does not give much info like left or right.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
