Starting issue
Old Jun 22, 2010 | 10:25 AM
Willis08tc's Avatar
Starting issue
This happens every now and then, i will go to start the car and its starts cranking i let go of the key and it keeps going. Cranks between 10 and 15 seconds then finally starts. Runs rough for a little bit but my afrs dip between 9.5 an 10.5 and idle. Drive the car for a mile or so and its fine. Any ideas would be great. Thanx-Gary
Old Jun 22, 2010 | 11:42 AM
Jbowman62's Avatar
does it happen after you fill up? if so unplug the evap solenoid line to the evap solenoid
Old Jun 26, 2010 | 12:46 PM
Willis08tc's Avatar
Yea only time it does this. Whats the fix?? I dont want to unplug anything, id prefer to fix it the rite way
Old Jun 26, 2010 | 04:06 PM
Malaclypse's Avatar
Under warranty? Take it in and complain of an extended crank.
Old Jun 27, 2010 | 10:49 AM
Jbowman62's Avatar
evap purge valve is hung open same thing happend to mine thats why i sait pull the line off the evap vave next time u fill it upand see if it helps and as far as a extented crank at the dealerships good luck with that
Old Jun 27, 2010 | 10:55 AM
RYRO14's Avatar
Had this issue, threw a code (I think it was P0496 Evap High Purge Flow Fault) went to the dealer and was fixed under warranty. Just wait you will probably get a random CEL in a couple days and take it in.
Old Jun 27, 2010 | 08:43 PM
slapbetcommissioner's Avatar
Did you unplug the battery prior to this happening?
The computer seems to need to run a quick check after it's been off and it seems to crank for about 10 seconds before it starts.
Old Jun 27, 2010 | 08:56 PM
roderick's Avatar
Take it to the dealer tell them whats happening.
Old Jun 27, 2010 | 10:23 PM
Cypher-'s Avatar
The car is supposed to crank on it own after letting the key go. Its listed in the manual that it has a computer assisted start or something like that and it will only stop if the car will not start after a while. I don't have the manual in front of me so I cant be more specific.
As far as the problem goes I cant help.
Old Jun 28, 2010 | 08:11 AM
Willis08tc's Avatar
Cool thanx i have had the p0496 high purge flow code on an off for about a month now. I unplugged the solenoid to see if it would help, bit either way it still does it. Ill take it in to the dealer when i get some free time
Old Aug 11, 2010 | 02:27 PM
SSpdDmon's Avatar
This just started happening to mine. The last two fill-ups has it running rough on the first start up. Rev it a few times and it's fine. Same DTC - P0496. Anyone know if this is covered under the extended powertrain warranty? I'm at 41K already on my '08.
Old Aug 11, 2010 | 07:09 PM
SSlobalt's Avatar
If not, I believe it's a cheap part and extremely easy to get to.
brandon04
Oct 21, 2015 07:04 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
