Stock Boost Levels......
Old Mar 31, 2009 | 07:07 PM
cresintern's Avatar
just wondering what kind of STOCK max boost LEVELS some of you ss/tc guys are seeing? IF U WANT TO POST UR MAX BOOST LEVELS WITH A TUNE AND MODS, THATS COOL ALSO.
but mostly want to see bone stock max boost levels?
and please don't be a lying bonehead and bum everyone out by bs'ing and saying your running 25psi bone stock....
and what gears are you seeing your highest levels?
ambient air temps would be helpful also....
Old Mar 31, 2009 | 07:09 PM
Mazdaboi318's Avatar
learn down....
there is no normal...
depends on the weather.
just a min ago. 70 degrees outside. 13 pounds. max
Old Mar 31, 2009 | 07:10 PM
hilty003's Avatar
stock
2nd gear
~16-17 is the highest ive seen but should just depend on temp, elevation, and other factors
Old Mar 31, 2009 | 07:17 PM
cresintern's Avatar
sounds bout right so far, good to see some honesty..
Old Mar 31, 2009 | 07:24 PM
eiuprtycntrl's Avatar
spike to 25 then settles to about 21-22 psi (trifecta tuned)
Old Mar 31, 2009 | 07:27 PM
glhs379's Avatar
stock i used to see about 15 or so
Old Mar 31, 2009 | 07:28 PM
cresintern's Avatar
sounds bout right for trifecta, vince spoke of temp 25 spike , then settling at 21-22, btw, is it spiking or creeping to 25? what gear? was it cold out?
i wouldn't want to hold 25psi for any longer than like a second!!!
cresintern's Avatar
Old Mar 31, 2009 | 07:32 PM
EvilleCobalt's Avatar
Means right when you go WOT the boost goes to 25psi the settles in around 21.
Old Mar 31, 2009 | 07:46 PM
^ yep. It is a VERY quick spike and a VERY quick settle back to about 21. nothing to be concerned about
Old Apr 1, 2009 | 12:29 AM
agent007kimball's Avatar
Stock I have never seen over 16 psi...lowest ever was 9 psi
Usually somewhere around 14
Old Apr 1, 2009 | 12:34 AM
HB_SS/TC's Avatar
Stock 14-16
Tomorrow I'll find out with the Trifecta tune
Old Apr 1, 2009 | 12:40 AM
tomj77's Avatar
u know i live in canada, nice and cold, in -20 i got 16psi, at +2 i get 16psi, with a hahn intake i get 16psi. mine doesnt change at all, doesnt matter what temp it is or if i got the new cold air intake. is mine not doing any down learning or what?
Old Apr 1, 2009 | 12:47 AM
NarutoDF's Avatar
i was on the highway and i was doing 55mph when i dropped it down into second while competitive mode was on and i managed to spike it to 16Psi. thats the max iv ever been able to get it to. after that once i get to third the most iv ever achieved is around 15Psi at peak then it goes to about 10-12psi pretty much the rest of the way.
Old Apr 1, 2009 | 01:02 AM
Gimpster's Avatar
I've never seen my car > 15/16psi and its still cool out. By redline it seems to be down to the 12 range or so?
Old Apr 1, 2009 | 01:32 AM
steviepc7's Avatar
16 max for me
Old Apr 1, 2009 | 06:45 AM
turbo08ss's Avatar
stock for me was right around 17-18 but now shes trifecta tuned and thats about right 21-23 but spikes to about 25 for like .001 of a sec and settles down
Old Apr 1, 2009 | 08:43 AM
ah665's Avatar
ive maxed around 16ish.
i need a tune
Old Apr 23, 2009 | 03:09 AM
SilverSSedan's Avatar
i just asked this on a different thread and looked around a bit and found this... i get about 15-17lbs and its been anywhere from 35-70 degrees out... dosent seem to change.. this is in 2nd and 3rd.... 1st is so fast i dont have time to look, and 4th and 5th.... going so fast i dont wanna take my eyes off the road...
Old Apr 23, 2009 | 11:43 AM
austinss's Avatar
x2 with 1st gear. In 2nd and 3rd highest I've seen with my week of ownership is 17psi.
Old Apr 23, 2009 | 12:04 PM
xray_racer's Avatar
18 psi max. All stock engine and 4500 ft of elevation.
Old Apr 23, 2009 | 12:13 PM
80vetteL82's Avatar
+1 I live in New England and the weather changes every other day...right now its 50, tomorrows supposed to be 70, and sunday 80.... throughout the year Ive had it Ive consistantly stayed at 15-16psi. This leads me to believe that elevation is the main factor in the learn down, not the temperature, but thats just my opinion.
Old Apr 23, 2009 | 01:03 PM
Terminator2's Avatar
Mine was always 15-16 psi as well it can be 30* out or 100* it was always the same. The temp does not change the density of the air enough to cause the ECM to up the boost to make the desired air load stock. Altitude changes will make a difference though.
Old Apr 23, 2009 | 01:19 PM
theguard's Avatar
most I have seen is 120 KPA (in Canada) or a little over 17 PSI. It normally hits that in second gear. It's been less than 10 degrees celsius when I do that, I don't try and push it in anything in the negatives (especially with performance tires still on in the winter lol)
Old Apr 23, 2009 | 01:39 PM
SSpdDmon's Avatar
Find someone who lives in Denver in another area of high altitude - they'll probably have the highest stock psi levels you'll find. My guess is ~19psi is the highest anyone will see stock.
As for me I drive in an area where elevation varies around 700~900 ft above sea level. In the winter, I would see 12~13psi tops. In the summer, I'd say ~15psi tops.
