Stock Boost Levels......
Old Apr 23, 2009 | 01:53 PM
Terminator2's Avatar
Originally Posted by SSpdDmon
Find someone who lives in Denver in another area of high altitude - they'll probably have the highest stock psi levels you'll find. My guess is ~19psi is the highest anyone will see stock.
As for me I drive in an area where elevation varies around 700~900 ft above sea level. In the winter, I would see 12~13psi tops. In the summer, I'd say ~15psi tops.
Stock they can see as high as 22 psi but the DA would have to be 8000+
Old Apr 23, 2009 | 02:23 PM
xray_racer's Avatar
Check it out:
http://www.digitaldutch.com/atmoscalc/
Air Density at Altitude:
Sea Level ---> 1.225 kg/m^3
5000 ft ---> .736 kg/m^3 [Edit: This is actually for 5000 meters. oops. 5000 ft should be 1.055. Only a 14% difference.]
That's a 14% drop in air density. So the turbo has to compensate by pumping in a greater volume of air. 14% greater.
Temp also makes a difference, but not nearly as much: [Edit: Actually a bit more with a 100 deg change.]
60 °F ---> 1.225 kg/m^3
160 °F ---> 1.027 kg/m^3
A 16% difference with a 100 degree temp change.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
