stock bov bolts
If the bolt threads are "messed up" then the threads in the turbo itself are probably shot. You'll want to check the threads with a tap and make sure every little metal filing is vacuumed out.
Not a good place for a cross threading. Be extremely careful here, as you could lunch the motor if this is done wrong.
i screwed on of those up once, found another bolt that was similar, retapped the hole and got it tightened up again, gotta be super carful. hope u didnt screw em up to bad
