Stock k04/ built motor vs. Stock motor/ bolt-on turbo
okay, i have already seen it...so what is it that you wanted me to see?
i didnt say the "peak power" would be more for the built/ stock turbo, i was trying to say the delivery and midrange and torque would be much better and safer...therefore lasting longer without issues, and running the same 1/4 mile times
I thought ZZP/ Matt had answered your question in the other thread?
Originally Posted by Matt M
A ZFR can't be touched by the stock turbo regardless of engine mods.
And fwiw, my s256 at low boost 16psi ( 25 psi high ) is quicker than my tuned 24psi gms1. That 's fact.
yeah, but its their new part that just came out, so i am sure they are a little biased...i was looking for real info stating like..." hey, you will never be over 350whp with the stock turbo, and on the zfr you can get that on just 20psi"...as an example
I am really thinking if you build the motor up and keep the stock ko4, it would be just as fast or slightly faster than a car with a stock motor and a bolt-on turbo at the same price while being safer because the engine is built obviously.
1. ZZP Cam with larger fuel lobe $850
2. ZZP 82# valve springs/retainers $350
3. WISECO pistons $550
4. valves $400
$2150
Lets start the debate....lol
4. valves $400
$2150
Again, compare apples to apples with just using the stock turbo as an example. If you keep the same displacement, same air flow, same compression ration and same fueling (fuel lobe doesn't really benefit you much as far as power goes when talking stock turbo) however just build the engine with stronger internals, that does not equate to more power.
So far I'm impressed with the Zzp Efr setup... First I was iffy, but after dealing with a few it's well worth te money. Good job guys
I am sure you have seen this over on the other thread. With that kind of endorsement coming from James, and we don't need to rehash the history between the 2 parties, that has to count for something. Just wait a little and see what # are people producing from the ZFR.
Im planning to get the synapse turbo kit next summer. Its everything I need. Full bolt on setup, tune, turbo swap and 370WHP.380WTQ.
Cant honestly see myself needing more than that in a FWD car! And all for pretty cheap.
the synapse kit is $4000 and makes less power than the BNR, so why would you want that kit?
And here is the info I was loking for..thread done..lol
People build their motor for reliability. Yes you can go big turbo and stock motor, but I guarantee at some point it will take a ****. IMO build the motor and get it ready for a big turbo. All opinion tho...
obviously, through a computer i cant tell sarcasm, tone or anything, but it seemed through how it was said, you were taking a shot...no worries...
Anyways, so basically you guys think that not only will a built motor not be close, then it wouldnt make any power at all over a stock motor/stock turbo???
zzp, TERm2, and James need to chime in because I think they have the real numbers so we all know...if i'm wrong, fine, but i wanna see the facts that a built motor/stock turbo is not that good.
And how quickly depending on the amount of abuse the owner puts on the engine. OP don't want to spend $10k+ for 370whp his budget is around $2k and his choices were built motor or tubo upgrade and not both.
A built motor with more compression utilizing the stock turbo would make a good amount of power with ethanol. However, you still can't change the fact that the turbo is signing off by 4700-5K RPM and out of breath by 6K.
A properly sized, more efficient turbo on a stock motor will always make more power and be just as reliable (tune being a huge variable here) as a built motor with the stock K04. Less heat and more airflow = win win
Yes but people had grenade their engine with stock turbo and bad tune. At some point an engine will fail
Even if you build the motor your not making 370 whp for long with a built motor. It doesn't matter how strong you build it, throwing the timing needed to make 370 whp with a small k04 will still cause sporadic KA and Det. A engine is only so strong beat on it long enough pushing the k04 way way out its efficiency range like that and see if your not spending another 2.5+k to rebuild your built engine again. You can't change physics there have been people in your thread who have been pushing the cobalt platform to their limits for years listen to them.
No what I meant for a turbo kit and built motor $10k+ including tuning and supporting parts. My turbo kit, install, tuning, clutch and flywheel, stage 1 cams/fuel lobe, and springs cost up there over $6k but not $10k. I could do it cheaper myself but I don't want the headaches.
