stock trifecta tune dyno stats
Old Aug 31, 2011 | 06:38 PM
  #51
Boosted4's Avatar
Actually, 4th gear is closer to 1:1, but the general consensus is to dyno in 3rd gear. The reason being is though 3rd gear is slightly farther from 1:1 than 4th, the difference is minimal, and it puts a lot less stress on the clutch if you dyno in 3rd as opposed to 4th.
Old Aug 31, 2011 | 08:21 PM
  #52
Chevycobaltss3's Avatar
the lnf tranny is /F35 final3.82 first 3.38 second 1.76 third 1.18 fourth 0.89 fifth0.70 which is closer!!!
Old Sep 1, 2011 | 02:43 AM
  #53
Boosted4's Avatar
1.00 - .89 = difference of .11 (4th) <-------
1.18 - 1.00 = difference of .18 (3rd)
Old Sep 1, 2011 | 08:50 AM
  #54
4th puts more stress. so if tq is what someone wants to see 4th is where its.
Old Sep 1, 2011 | 11:08 AM
  #55
mongorat427's Avatar
Thats the advantage of the 4.45 trans. Much Less stress on the gears due to the mechanical advantage it offers
Old Sep 1, 2011 | 01:04 PM
  #56
Fastgti69's Avatar
Is all the mph the same.. IE: 1st gear goes to 35 mph 2nd goes to 67 3rd gotes to 100 is that all still the same? What has been done to the tranny besides some final drive ratio. I'm a newb when it comes to tranny info..
Old Sep 1, 2011 | 01:16 PM
  #57
Every thing is 600 rpms higher so you go through the gears faster. The trans is put together with tighter clearances , Gears are profiled on the contact edge for better durability, shift mechanism is reworked for smoother shifts,input shaft is polished and I supplied my own Cryoed 4.45 gear set. Got over 500 miles on it now.
Old Sep 1, 2011 | 11:21 PM
  #58
Fastgti69's Avatar
Not too bad then. Thanks for the info dude
Old Sep 1, 2011 | 11:32 PM
  #59
lazaro's Avatar
thanks bro,
bigdeertz
Nov 17, 2016 09:41 AM
Sep 27, 2015 08:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
reybalt
Sep 25, 2015 08:28 PM
