Suggestions??
Suggestions??
i have a 2009 TC. for xmas i got a catless zzp dp. i already cut out the rear muffler so its basically gonna be straight pipe only.. im gettin the dp put on tmrw morning and was wondering if theres any suggestions of mufflers to run? or run straight pipe?
I had catless and MD, it sounded like a pissed off lawnmower. I quickly put the stock muffle back on. Mufflers do nothing for performance gains and the stock catback and muffler with catless DP is teh sex.
I have a catless DP and MD, and I actually like the sound it gives me. Once you get to about 3500 RPM's it gets loud, yes, but I love seeing the looks on people's faces when I pass them and let her growl a little at them
mandral exhaust system.com has 3 inch cat back with a couple different mufflers to choose from and about the cheapest around. i went with a strait through magnaflow that sounds good. by the way are you from okc area?
lol
havnt talked to you much since you turned your car into a little monster
The only problem I really have with the Catless DP and muffler delete is that...on a cold start up...you will wake up everyone within a 4 block radius until it is done with its cat-warm-up mode.
I'm actually debating putting on the stock muffler again or going for an aftermarket muffler strictly for that reason.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
