Superchips and Downpipe?
I have a Superchips tune right now with a Hahn intake and ZZP upper charge pipe. I just ordered ZZP's catted downpipe. My question is, will I be ok in terms of fuel trims? Will I be running lean and is it dangerous? The rest of the exhaust is stock.
I really don't want to change tunes.
hmm I'm not sure how good the superchips is at learning mods or how their afr's and trims are. Cant you get it retuned? I thought SCT offered a software to tune some yourself on a computer? I ask because Its the only tuning for my escape, so I've been reading into it.
You are already running lean with the Hahn intake. I'll bet your fuel trims are +10 or higher. The DP shouldn't change it much but you should get a real tune & have it logged & tweaked for the intake.
I had superchips and a ZZP catless downpipe and it ran great . The thing that messed with the fuel trims on my car was the K&N filter and airbox mod. I saw a high as -9 LTFT but when i put the stock filter and uncut airbox back in the trims were back to +/- 1 .
Yeah mine too.... the car wouldn't want to go on a cold start .... even with the water temp at 130-140 it would bog out at 1/2 throttle . The superchips tune is a good tune IMHO .... but you need to realize it is meant for a bone stock car . They say bolt on's arent supported by the tune .
the DP will throw a couple of codes though(all o2 related), so be prepared for that
yeah, you may throw codes like P2261 ( two MAFS) or P206(I think) for fuel trims off. The p2261 is caused by your pcm reading different flow readings then stock, so if the two don't match up from air entering into the intake and out the dp where the turbo manifold is, then you'll get kicked with the p2261, and maybe 25% possibility into LIMP mode. That's coming from my experience, sinced all I have is the just the Injen CP and ZZP Catless DP with GMS1, but very rare my car will go into LIMP mode. Here is a forum about P2261. But, I'm sure it was the BPV being the issue for not opening up enough and you get that turkey sound.
yayer. kretty from MN just called me and said his hahn was throwing his trims by +7-12 on a gm stage 1 tune... yikes. So the intake needs to be tuned for or I say get the k&n.
no... running the ZZP on the stock gasket, exhaust guy said it was the best fit he'd ever seen with a stock gasket
as far as tuning, either trifecta or BYT, both which take advantage of Vince's unlocked tables
i'm bolt-on(dp,cp,intake) with a "mild" 22-23psi Trifecta tune and can take Ls3 camaros, etc... no world beater but quite the sleeper
The downpipe isn't going to screw the superchips tune up so you don't have to worry about that . The CAI is what messes with the fuel trims . I would use the SC tuner to log and or watch what the fuel trims are doing .
yeah the only thing you need to get tuned off of the downpipe, is the codes it throws... car will run fine
and for some reason, the catless downpipes seem to be better at not throwing codes, I just didn't want my car that loud
Yep the newer catless downpipes with the extended o2 bungs are pretty good about not throwing codes. Mine hasn't thrown a code for atleast a year........ but it did throw one or two the first month or so that it was on . Bama's right about the sound increase too. When you get on it ....it's pretty loud ...even with the stock catback .
actually a cold start is when a Catless DP is REALLY loud... I mean it gets quiter... you know, after you wake everyone up in the morning cranking your damn car
if it was just loud at WOT, I would have gotten one
