Thinking about a mild build
Old May 25, 2011 | 10:02 AM
watrboy821's Avatar
Was thinking about a mild/reliable build and wanted some input from people. 350-360hp. Anything else you think I would need, please comment.
Would want:
-Forged pistons (to solve the possibility of piston failures we've seen)
-78# Springs with Retainers? (to help with the high boost)
-ZZP EFR Turbo or Precision Turbo Upgrade (basically looking for a bolt-on turbo upgrade, looks like the EFR when it comes out will be the one.)
-ZZP Stage 4 clutch
-ZZP Intercooler
Would need?:
-New Headstuds
-New Flywheel Bolts
-New Head Gasket
Currently have:
-Trifecta tune
-K&N SRI
-Hot Side Charge Pipe
-Hahn high flow catted dp
-GM Stage 1 MAP Sensors
Old May 25, 2011 | 10:17 AM
MastaShaKe_88's Avatar
click
Old May 25, 2011 | 10:33 AM
elecblue06's Avatar
the bnr stg 2 2871 is the only thing that is available
Old May 25, 2011 | 10:34 AM
watrboy821's Avatar
Originally Posted by MastaShaKe_88
click
Old May 25, 2011 | 10:35 AM
watrboy821's Avatar
Thank you, didn't know they never went through with the 2860, it is on their website. I'll look into ZZP's bolt up turbo that has been talked about.
Old May 25, 2011 | 11:07 AM
cmiller8006's Avatar
all you need is a zzp s252 turbo kit and a clutch and you are ready to dock. 400 whp and the motor will be just fine. Screw all this bnr bs people always state. S252 spools quick, hand hangs strong up top. The bnr turbo are a good option if you want to throw your money away. Also the 252 will be able to be turned up on the occasion, say your going to a meet and want a little extra, turn it up and there you go. Stock motor will live a long time at 425-450whp.
Old May 25, 2011 | 11:09 AM
elecblue06's Avatar
it's up on their site but they just realized it wasnt worth it .. the 2871 on the other hand is definitely worth it
Old May 25, 2011 | 11:12 AM
elecblue06's Avatar
.... common man .. really your gonna bash after seeing the numbers the 2871 put down.. it's not throwing his money away.. that turbo will get him to where he wants and much more..
even zzp has said the 2871 is a good turbo for something they wont offer.. without going new turbo kit (which is more expensive then just the bnr turbo)
Old May 25, 2011 | 11:35 AM
watrboy821's Avatar
I just want a bolt-up turbo. I would put the pistons in for sanity, after seeing the ringland failures people are having. I was looking through the 2871, but I don't want to have to deal with a BOV. I am thinking that the ZZP EFR turbo is my best bet if/when it comes out. I can probably do without the valve springs and retainers, but I see the pistons as a must.
Old May 25, 2011 | 11:56 AM
I see the springs as more of an issue than the pistons.
Old May 25, 2011 | 12:23 PM
I never seen any numbers. What did it put down?
Old May 25, 2011 | 12:27 PM
elecblue06's Avatar
393 4XX on a mustang dyno
Old May 25, 2011 | 12:41 PM
Thats not bad. I really didn't think they would make that much.
Old May 25, 2011 | 01:28 PM
yellowss7590's Avatar
go zzp kit and that 252et i have it best turbo ive had experience with
Old May 25, 2011 | 02:40 PM
Supercharged Guy's Avatar
I'd just buy the kit from ZZP and call it a day, that way when you want more power you can easily have it
Instead of swapping turbos out, etc
Old May 25, 2011 | 02:47 PM
HHRSSouth's Avatar
Haters gonna, hate.
That is all.
Old May 25, 2011 | 03:49 PM
elecblue06's Avatar
no one did and there is still room to grow
06MetallicBalt
Jul 20, 2025 08:47 PM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
