Throttle body install
Old Dec 28, 2017 | 02:03 AM
Teal94Z's Avatar
Hey my TPS went out and i need to install a new throttle body i was wondering if there are any how-to's to make life a little easier, it seems like a pain to swap out. thanks in advance
Old Dec 28, 2017 | 08:21 AM
jdbaugh1's Avatar
How did you determine your TPS went out? I haven't personally been up and close with the LNF but I would think the throttle body replacement is similar on all of them. Should just need to remove the intake bits that are in the way and the throttle body comes unbolted from the intake manifold with 4 bolts.
Old Dec 28, 2017 | 10:11 AM
umrdyldo's Avatar
1. Disconnect battery
2. On the side of the TB is the electrical plug, undo the tab then squeeze and remove the plug. Typical for many plugs on the Cobalt. It works like the MAF on the intake if you need practice.
3. using a screw driver loosen the hose clamp on the charge pipe connected to the TB.
4. Remove charge pipe. This can suck and sometimes have to use a screwdriver to pry it off.
5. Raise the front of the car to be able to get under it.
6. Gather a ratchet and several extension and the proper socket and undo the 4 bolts on the throttle body. I think it's 4 15 mm bolts but not sure on size
7. Remove TB.
8. Reverse steps.
Pitbull2o08
Apr 19, 2013 05:56 PM
robzqc
Jan 9, 2013 03:24 PM
kieran B
Nov 2, 2010 07:04 PM
BlueSSupercharged
Sep 3, 2009 02:26 PM
Spanky's Monkey
Aug 10, 2007 10:59 AM
