Tial BOV
idk about our vendors but u can get one online
http://www.nolimitmotorsport.com/tia...FR4HagodRS_7mA
Have you by chance looked into the synapse BOV?
http://www.turbotechracing.com/produ...7&idcategory=0
Just a thought, many have it.
if you run an atmospheric bov none of these work properly. they cause the car to run poorly because the ecu has no idea where the air is going. clear image has come out with a proven kit but dan is still waiting to get the wiring extensions. using an atmospheric bov requires more an aftermarket charge pipe with the correct flange.....if you want it to be compadible with the ecu the sensor needs to be moved and reprogrammed. talk to dan at clear image. tial is the best bov out on the market.
also all bovs are easy to install. its normally a piping that can sometimes be a pia. one option you have is to get the synapse or hks and recirculate it back to the intake. to me its pointless unless your making big horsepower because it doesnt sound that much louder then stock
Cptnslo
Sep 24, 2015 09:32 AM
