Tial BOV install
Old Jun 6, 2011 | 08:57 PM
iTwitch's Avatar
Tial BOV install
Ok so I have an HKS on my DeJon pipes. Well Im about to throw on this Tial on Dejon pipe. Question 1. - Which spring do I use. And if needed how many washers?
Question 2. - What vacuum line should I use? Any guidance will be sweet! thanks!
Old Jun 6, 2011 | 09:23 PM
iTwitch's Avatar
bump?
Old Jun 6, 2011 | 09:32 PM
05Slowline's Avatar
washer on each side of the fitting top and bottom
dunno which line lnf use for boost ref lol
http://www.tialmedia.com/documents/w3_tial_bov50_sp.pdf
i would say white or unpainted
Old Jun 6, 2011 | 10:10 PM
RyRidesMotox's Avatar
That is how I routed mine. The vac solenoid nipples should be connected as such...
Top (closest to back of car)- originally connected to the lower charge pipe... must remain connected to a boost source, either back to the lower cp or (as the treadstone stuff has no lower cp nipple for the vac line) it must be "T"ed into the line that runs to the intake mani from the vac tank.
Left (passenger side) should be originally connected to the stock BPV. This will connect directly to the new BOV and you will need to block off the BPV port in your turbo.
Bottom- should be left alone as this goes to the vac pump tank.
That is how my 52mm TurboSmart is routed.
Old Jun 7, 2011 | 02:01 PM
efactor's Avatar
make sure you post pics and videos. I never heard what Tial BOV sounds like with our cars.
Old Jun 7, 2011 | 02:12 PM
09CobaltSS1's Avatar
psssshhhhhhhhhh... that about sums up your sound clip
Old Jun 7, 2011 | 02:13 PM
Drewbroo has one on his I think (Tial Q maybe?). He has a video floating around here somewhere.
Old Jun 7, 2011 | 10:27 PM
iTwitch's Avatar
I never got around to hooking it up. I went and got tuned today and was out wasting gas haha. This was helpful thank you and I will see if it works out! I will also post a few pics and videos .
Old Jun 12, 2011 | 09:59 PM
iTwitch's Avatar
This did not work.
Old Jun 13, 2011 | 03:34 AM
Originally Posted by iTwitch
This did not work.
Which part? We need pictures at least and a description of whats going on.
Old Jun 13, 2011 | 11:23 AM
paintballerr78's Avatar
check your spring....i have a zzp bov same as a tial and the spring was way to heavy to open the bov all i got was turbo flutter. But first try attempting to T it into the line coming straight off the top of the manifold*the one were Ryrides has a t on and see if that works cause thats directly to a vacuum source
Old Jun 13, 2011 | 04:25 PM
iTwitch's Avatar
I had differed springs in it. Didn't work. Tried to hook vacuum up several ways and got nothing. It doesn't blow off, and it should blow off and I should be able to hear it.
Old Jun 13, 2011 | 05:17 PM
BooSSted's Avatar
Run it directly to the vacuum line on the top of the intake manifold. If it doesn't work, you're springs are wrong.
Old Jun 13, 2011 | 11:13 PM
Pictures of current setup and at least a little video of the problem. Without being shown a problem people cant really help.
Old Jun 15, 2011 | 10:30 AM
lil-red-89's Avatar
yes video's and pictures since you're using my piping lol i'd like to see or hear whats going on since i cant physically be there (in korea)
Old Jun 21, 2011 | 11:50 PM
bmain0407's Avatar
get a pink bov spring its the stronger spring and run the bov line right to the manifold then just jumper the sensor thing with a 4 in piece of tube from one side to the other kinda just disables the sensor. havent had any problems yet. little flutter but not as bad as it used to be.
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
justinchinn
Oct 2, 2015 12:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
