Tial bov and spring
Old Apr 18, 2011 | 05:07 PM
paintballerr78's Avatar
Tial bov and spring
Ok im going to be putting a 5557 turbo in my car and i know our vacuum at idle is around 19 or so. Now with the different turbo will this change. Im getting a zzp bov one looks like tial and it has a 21inch spring and im thinkin this may be to much. So if anyone could help me would be appreciated
Old Apr 18, 2011 | 06:11 PM
NJHK's Avatar
It should not change. Your idle for one is determined by your idle air controller and your turbocharger isn't building pressure either.
Old Apr 18, 2011 | 06:37 PM
InfraRedline's Avatar
So use the vacuum line from the factory BPV instead of any old vacuum source?
Old Apr 18, 2011 | 06:38 PM
whats the best way then to hook up a tial bov
Old Apr 18, 2011 | 06:43 PM
He just told us
Old Apr 18, 2011 | 06:49 PM
so i need a new spring then not the 21in spring that comes stock with the zzp one?
Old Apr 18, 2011 | 09:45 PM
ya im gonna do a maf relocate to the coldside piping
whyyoumadson?'s Avatar
boosting 25psi the tial wouldnt even open with that spring. i just ground down the spring and it works beautifuly now but you can always purchase the smaller springs. i thought they usually came with a 14 spring or something around there.
Old Apr 18, 2011 | 09:46 PM
Ya they usually do but zzp has a bov its basically a tial i guess and its 65 bucks. So i could either buy a new spring or cut it down i guess
Old Apr 18, 2011 | 09:53 PM
BLAZIN07SS's Avatar
I'm too JDM for you
it should open fine on the 21 inch spring. how much vacuum does your car make at idle? typical lnf's make 21 in/hg. so you would use the 21 spring in the zzp bov. zzp tried to make it simple and most still confuse it
Old Apr 18, 2011 | 10:09 PM
yeah you can always cut it down. i know when i had the larger spring in there the bov didnt even want to open but i have an authentic tial./
Old Apr 18, 2011 | 10:16 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by HHRSSouth
You have no idea what you are talking about when it comes to putting the Tial BOV on a LNF
how so? it works on pure vacuum. as long as it's hooked up to a pure vacuum source with no tee's in it to any other crap, it will open fast and crisp
ineedacobaltss
Nov 7, 2015 02:25 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
