ticking noise not the normal ones
Old May 1, 2012 | 08:08 PM
BlackLsCoupe's Avatar
today i had to go to court to show i got ticket waived for tinted tails and get a court date for window tint. its been warmer like 50 out. i know theres ticking noises from the fuel **** and what ever else, this was like a metalic tick. almost like the valve train. ive had this noise once before on my old taurus when i forgot to tighten a rocker down. should i take it in and have them check the lash adjusters? and how could you get them to do that like just claim you think theres soumething wrong? also my exhaust sounds different when warmed up. i could be just parinoid since i keep fixing things every 2 months
for got to mention it goes away after a few min's
Old May 1, 2012 | 08:15 PM
TommyP's Avatar
AWD > FWD
I would expect a rocker or lash adjuster, could be timing chain tensioner depending on where it's coming from. If you've still got warranty I would absolutely let the dealership worry about it. You can use a really long socket extension as a stethoscope to try to hear where it's coming from.
Old May 1, 2012 | 08:29 PM
i didnt think of the timing chain. had plans to take valve cover off to polish and clear it and check the lashes while doing that but never have time these days. problem is it only does it at weird times most dealers go well we cant verify it if its not doing it. i could use the techs stethoscope from work if i hear it again.
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
