Tips for installing ZZP Clutch Rod
Old Aug 18, 2010 | 11:01 PM
D-mac's Avatar
Hello everyone
Could you guys give me some helpful tips or tricks for getting the ZZP Clutch rod in?
Ive read it can be a bitch to do
Thanks
Old Aug 18, 2010 | 11:03 PM
bykryder83's Avatar
It sux to install!!!! I broke me clutch master cyl and had to buy new one then start over from scratch
Old Aug 18, 2010 | 11:39 PM
Matt M's Avatar
Ryan is working on a instruction video. Its all shot, but needs to be edited and uploaded. Hopefully it will be up on our site soon.
Old Aug 18, 2010 | 11:41 PM
beast10007's Avatar
^^^ bad a$$
Old Aug 18, 2010 | 11:52 PM
redstarpa69's Avatar
Matt,
My clutch and rod are working great, the pedal feel and clutch engagement is awesome!! I'm glad I got it.. I know I can adjust it to my driving styles or clutch wear.. it's def a best buy investment.
Rudy
Old Aug 19, 2010 | 12:12 AM
bykryder83's Avatar
Matt, why does my clutch rod look like garbage compared to the newer one?? Mine looks like factory. Its very small compared to the new one my buddy received.
Old Aug 19, 2010 | 12:16 AM
D-mac's Avatar
Im doing this tomorrow for the track this weekend
Can you give me some tips or instructions ?
Old Aug 19, 2010 | 05:42 AM
Iam Broke's Avatar
Have you seen my thread on it?
Maybe something here will help you. I got it, but it took time, blood, sweat & tears.
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/zzp-clutch-rod-install-help-please-208059/
Old Aug 19, 2010 | 09:15 AM
Matt M's Avatar
I've never changed one, so I wouldn't be much help.
Old Aug 19, 2010 | 10:44 PM
D-mac's Avatar
Well well well
Stock clutch rod broke off the ball in the master cylinder !!!
Pull it off with the pedal my ****
If anyone is going to install one of these just save yourself the headache and pull out the entire master cylinder
Looking at the design of the cylinder the rod is not meant to come out with the plunger pulled all the way out towards the clutch pedal
For anyone that is going to try this with ZZP instructions here is the part number for the master cylinder i now have to go buy 24246918
Old Aug 19, 2010 | 10:45 PM
SSlobalt's Avatar
Dude, that sucks.
Old Aug 19, 2010 | 11:46 PM
turbaltss's Avatar
that's pretty shitty and to poor a little salt on the open wound the new master cyl. comes with a rod installed!
Old Aug 20, 2010 | 07:43 AM
bykryder83's Avatar
Yupp, and its like 100-120 bucks........FAIL!!!
Old Aug 20, 2010 | 03:51 PM
D-mac's Avatar
100-120 is fine
Its $330 here in Canada
The rod will come out like nothing once the Master is uninstalled
Been trying to call ZZP all day to see if i can buy one from them asap with no rod
Old Aug 20, 2010 | 04:02 PM
Blown07SS's Avatar
I was wanting to get the clutch rod to just don't know if it is worth it. Let me know if any one has it already I woul like to know.
Old Aug 20, 2010 | 05:39 PM
D-mac's Avatar
If you do get it either buy it in their new Master or Pull yours all the way out to replace it
Old Aug 21, 2010 | 01:26 AM
D-mac's Avatar
OK the master comes apart and we got the ball out
I don't suggest anyone trying yanking on it like the instructions say to
It is so much easier just to remove your master and do this mod that way
Bleeding the clutch is easy if you have the rod adjusted as tight as possible then you adjust the rod to where you want it
Old Aug 21, 2010 | 02:28 PM
Ryan@zzp's Avatar
The new clutch rod is our redesign. They are both made of the same material. We made the new rod out of hex bar some the customer had a spot to put a wrench when tightening the jam nut. I wouldn't say garbage is the correct description.
Old Aug 21, 2010 | 05:22 PM
beast10007's Avatar
yea you this to NLS
Old Aug 21, 2010 | 08:45 PM
Iam Broke's Avatar
It's worth it with a performance clutch. Just takes some work to get it done. I had some trouble as well but got it installed in the end.
bigdeertz
Nov 17, 2016 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
DocSvensk
Sep 27, 2015 02:24 PM
jas09ss
Sep 26, 2015 01:06 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
