tired of throwing a cel with a catless dp?
Old Mar 3, 2010 | 09:49 PM
Dart_SI's Avatar
its called a defouler. get one.
sorry, but i see this all to often, ppl saying theyre getting codes and dont know what to do. all you have to do is weld or screw in a metal tube where the 02 bung is to move the 02 sensor away from the down pipe. as a result less heat and gas goes to the 02 sensor and it wont burn it out or throw a code. pretty much the same principal as the angled 02 bung that comes on some of the downpipes.
i have yet to hear or see anybody talk about using a defouler as a solution. i could be wrong tho, i know this works on hondas and most other cars.
Old Mar 3, 2010 | 09:55 PM
HB_SS/TC's Avatar
I haven't gotten a code and its not even angled
Old Mar 3, 2010 | 09:59 PM
Dart_SI's Avatar
it could throw a code over time. it will definently wear out your 02 sensor sooner than normal.
Old Mar 3, 2010 | 10:00 PM
sundevil07's Avatar
or just get the code turned off when you get tuned
Old Mar 3, 2010 | 10:09 PM
Dart_SI's Avatar
if you dont like your warranty..
Old Mar 3, 2010 | 10:25 PM
G_Pelly's Avatar
i used a defouler, i had to drill it out so the o2 would fit, but the light was still on, so i just added another defouler and it worked
Old Mar 3, 2010 | 10:26 PM
austinss's Avatar
Or if you're tuned.....turn off the O2 sensor.
Old Mar 3, 2010 | 10:29 PM
Dart_SI's Avatar
thats if your tuned. the ppl who plan on staying stock or going gms1 could benefit from a defouler. warranty stays intact. im not getting an aftermarket tune till the warranty is up.
Old Mar 4, 2010 | 09:13 AM
BYT*SS*TURBO's Avatar
Most of the DP's come with a defouler built in for the 2nd O2, and that isnt the code we are throwing anyway Its 2237 - O2 pumping circuit.
Old Mar 5, 2010 | 12:41 PM
firerat's Avatar
Holy rice! Look at those headlights!
Old Mar 5, 2010 | 01:26 PM
Dart_SI's Avatar
Old Mar 5, 2010 | 01:35 PM
tom.g's Avatar
Can't you just clear the code with a code reader/clearer. I know it would probably come back eventually but wouldn't that work aswell?
Old Mar 5, 2010 | 01:48 PM
Dart_SI's Avatar
yes, it would work. however if you ever plan on going back to stock or something, your 02 sensor is going to be bad.
Old Mar 5, 2010 | 01:56 PM
Why would your O2 be bad from clearing a code? You have a lot of misinformation going on...
Old Mar 5, 2010 | 02:15 PM
koch1ar's Avatar
bad=fouled, dirty, contaminated, for being exposed. defouler pulls sensor away from gases (clearing a code dont do that).
his info seems spot on
Old Mar 5, 2010 | 02:17 PM
rico's Avatar
edit. ha didnt see this was for lnf's sorry ha
Old Mar 5, 2010 | 02:18 PM
All of the LNF downpipes come with the angled bung/defouler piece already. The code we are throwing isnt a cat efficiency code, its a 2237 O2 pumping circuit code. Not related..
Not to mention the 2237 code is sensor 1 bank 1..
Old Mar 7, 2010 | 04:58 PM
tom.g's Avatar
If someone with a catless DP gets this code do they have to have it removed by a tuner (HP or Trifecta) or would clearing it with a reader/clearer work? Is there any adverse effects to clearing this code?
Old Mar 8, 2010 | 05:50 AM
Sweetsandman's Avatar
Orrr...disable the related CELs like we HPT guys do ...oh and defoulers don't ALWAYS work. They are a lot like the angled O2 bungs...you'll probably never throw a code for being too rich...but there are plenty of other rear O2 related codes you can throw with these things. Just sayin.
Old Mar 8, 2010 | 05:51 AM
G85 SS's Avatar
Or you can delete the code with HPT.
That's the ghetto way.
Old Mar 8, 2010 | 09:15 AM
Not to mention that doesn't cure the issue..
Old Mar 8, 2010 | 10:43 PM
Oxidy's Avatar
Sarcasm? I hope..
Old Mar 8, 2010 | 10:47 PM
badbaltguy's Avatar
everytime i open my cutout which is AFTER both sensors, i throw a low voltage code which then causes a fuel trim code and 2 or 3 other ones. never fails. i dont get it. but with it closed, i never get any codes....
Old Mar 9, 2010 | 03:08 AM
09BlueBaltSS's Avatar
Your gonna wait 5yrs to go after market?
Old Mar 9, 2010 | 10:19 AM
firerat's Avatar
Originally Posted by Oxidy
Sarcasm? I hope..
I was talking about 'Honky Boy's' headlights, 1. They are too blue 2. They appear to be HID's installed in stock halogen housings.
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
