Too Rich?
What gear is everyone dyno'ing the car in....That could play a huge roll into this...In my experience Turbo cars are always done in 4th, as well as RWD (typically its 1:1) or 5th for cars w/ a 6speed. Dyno'ing for many FWD's is done in 3rd...which could lead to higher numbers
@ 120-130 mph my car ran out of steam (I blame lack of air movement and 6th and final run) 287/342 are great numbers considering I didnt have the fan blowing on the engine anymore (the switch went out).
Car has had no issues since being tuned (and has been tuned for 2500'ish miles)...Its just recently been running the stock ecm to get a baseline (and was at the dealer for 2 weeks getting some rattles fixed)
The only question really comes up as to who is correct w/ the A/F setups....Seems the leaner is winning, but I trust Vince and will have better same setup run next time I get some a day to run over to the dyno.
3rd=higher HP to wheels based on higher then 1:1 ratio
4th=lower HP then 3rd due to frictional losses because it is lower then 1:1 (.89) but it is the closest ratio to 1:1 thus, the car should be dyno'd @ 4th for accurate results.
Thats the way I've always understood it
So your dyno'ing in 3rd where the ratio is higher then 1:1...
3rd=higher HP to wheels based on higher then 1:1 ratio (false data)
Peak numbers in third and fourth are about the same. (Stock IC car heatsoaks kinda fast). 90% of number on here are 3rd gear pulls. Neither 3rd nor 4th are exactly 1:1 so there is no entirely accurate dyno results with this strange transmission we have. technically Hp number in 4th should be higher because it is an OD gear. Using a lower than 1:1 gear like third or 2nd actually results in less hp.
It is about 2-3 hp higher and the problem is those are not full pulls. When shifting the rpms drop but not the same amount because of the uneven gaps in the gear ratios. Yes, when my car was stock we used 4th gear some and 3rd gear the difference was so little that it really makes no difference. Here is the thing 3rd is 1.18 4th is 0.89. Both are about the same ratio difference from 1:1 exactly so one is going to read a tad higher than actual and one is going to read a little lower than actual. I watched a SRT4 caliber get dynoed and they did 4th gear which on that car and most others is 1:1. It made 307 whp, in third it made 294 whp, in 2nd it made 272 whp. The dyno will read lower in gears numerically lower than 1:1!!! Dont believe me? Dyno your car in 2nd or third if you want. 2nd will be a ton lower and third will be nearly the same because the ratios are very close together. Believe what you want.
Last edited by Terminator2; May 16, 2009 at 02:51 PM. Reason: Automerged Doublepost
It should be pretty close. Mine was within 2 hp from third to 4th.
Of course it will dyno different in 1st or 2nd for that matter....Mainly this applies to turbo cars....Your engine is outrunning the turbo, its that simple. A mustang dyno can load over a constnat time which would give you accurate information if you used a mustang dyno (not just any inertia type dyno)
You would know with your 200 total posts right.
Man, that torque seems really high compared to others with that same tune. HP is about right. How much load were they running? STD or SAE?
Last edited by Terminator2; May 18, 2009 at 08:48 AM. Reason: Automerged Doublepost
OMG! Thanks for calling me out on that. I'm so happy that the upper echelon members here feel the need to point out my sub 4000 post count, thinking that it means anything about my ability to look around and see all of the ass hats in this place.
You're only adding to the amount of mentally incompetent people on here.
I make a joke and get bashed...
I shall restate my first point, css at it's finest.
I am sorry I acted like an ass. I was in a bad mood. No hard feelings.
