At the track with stock turbo...
Ahh, I see. The DI fuel rail is built like a tank. I'm not worried.
Boost starts around 24 and fades to 17, or less if I rev high enough. With enough timing, HP stays flat close to 7k.
Surprised you aren't running more boost, honestly. GREAT numbers!
The fuel rail will not blow up. High pressure systems are always designed with a high safety factor, to guarantee that the stress they see is always under the fatigue point of the material, or under the desired stress vs number of cycle a part has to achieve, depending of the material used. I engineer hydraulic cylinders used in everything from oil field to forestry equipments, and every hydraulic related parts are designed this way. The lower safety factor we use for critical parts is 3:1, most of the time it's higher. Going from 2200 psi to 2800 is not dangerous. If the rail was designed with such a low safety factor that a 25-30% in pressure could blow it up, they would crack all the time from simple things as variations in the raw materials to machining imperfections and would never last for the life of the car.
Without knock, I'd think you could run more timing yet and not worry about bearings. It's not as bad as running 20 degrees of timing on gas and always having some knock.
Well, I loaded the 2800 psi Trifecta base file, did a pull and still tripped the P0087 Low Fuel Rail pressure at 6300 rpm in third on a 75% ethanol fill. Granted I'm exceeding 350% air load with the MAF freq tables raped 27% positive to get enough fuel, but IDK how you do it unless the 4.45 axle takes enough load off. Running .90 PE lambda. Any input appreciated Matt.
+1 Near 7-7.5k I am also close to 27.5-28* timing on a 2.7" TVS. 80k+ miles on stock bottom end and still going strong.
Ya, I worked very late last night so I haven't had a chance to look into the hardware needed to monitor it. I'll have to sort it out. Thanks for replying. I logged over 31 lb/min VE airflow in the midrange last night before it popped the CEL.
If you remove the valve core and then install one of these fittings, then you can use a 1/8" npt sensor. ZZP adapter
