At the track with stock turbo...
Old Oct 17, 2010 | 09:44 AM
  #51
mongorat427's Avatar
Wow wow wowzy!!!!!!!
Old Oct 17, 2010 | 10:21 AM
  #52
cardelino18's Avatar
very good times matt... congrats...
you guys are making cams for the car?
if so are you expecting any power out the the cams it self or just to rev higher with the big turbo set-up? (which obviosly will get you a good amount of power lol)
also what are you guys reving it up to with the valve springs?
Old Oct 17, 2010 | 10:22 AM
  #53
vahdyx's Avatar
I don't get why Brembos slow you down, I can assume, but I can't say for sure.
Anyway, very nice times. Congrats.
Old Oct 17, 2010 | 10:29 AM
  #54
whyyoumadson?'s Avatar
they slow you down mainly because you need to run a larger diameter rim....bigger the wheel bigger the rotating mass your trying to make go aread = slowing down. it wont be a HUGE difference but in racing every little thing counts.
i wanna say the minimum you can run on the brembos is a 17 and most need a spacer...shaved lsj brakes.....15's with a nice meaty tire like they run
Old Oct 17, 2010 | 10:30 AM
  #55
brembos dont slow you down... thy put the supercharged breaks in order to fit 15 inch or 16 inch rims for some good slicks...
Old Oct 17, 2010 | 10:46 AM
  #56
well its not the brembos themselves that slow you down...its just the fact that you need to run a larger wheel which will slow you down a bit.
Old Oct 17, 2010 | 10:50 AM
  #57
blacklightmachine's Avatar
Yeah the brembo calipers are actually lighter than the LSJ calipers IIRC
Old Oct 17, 2010 | 11:17 AM
  #58
cmiller8006's Avatar
The brembos are actually heavier than the lsj brakes. So even if you could fit a 15 over them they still would slow you down over the lsj brakes. It may not be much but it is some. And with a slotted rotor and a sticky brake pad they stop very similar to the brembos.
Old Oct 17, 2010 | 11:29 AM
  #59
ecotecturbo's Avatar
Very nice guys!
Old Oct 17, 2010 | 11:40 AM
  #60
09SS's Avatar
Originally Posted by blacklightmachine
I see how it was done now.
Do you use the port fuelers above a certain load?
There's finer atomization offered at higher rpms and read that you are using the DI system to do the brunt of the work as it is...almost like a dual shower set up on a F1 car, or close to how the dual injector setups run on bikes.
He has the stock head on the car.
Old Oct 17, 2010 | 11:43 AM
  #61
raver0789's Avatar
Quote:
stock airbox with ZZP mod
KN filter
ZZP silicone intake
confused.
So you're running the stock airbox with the zzp mod, plus you have an intake? Does that not mean you have no stock airbox anymore?
Old Oct 17, 2010 | 11:44 AM
  #62
i believe its a stock air box with the zzp mod and instead of the stock turbo to airbox connector they have their own silicone coupler.
Old Oct 17, 2010 | 11:57 AM
  #63
CrystalRedSS's Avatar
Originally Posted by Kyle4236
well i guess its another new record but if you put shaved street tires on it your 60' will drop to 1.6 at least
Lol oh jesus not that again
Old Oct 17, 2010 | 12:08 PM
  #64
Matt M's Avatar
I am not running the port fuel injectors. DI only, at this time.
lol, that just doesn't seem likely.
Old Oct 17, 2010 | 12:11 PM
  #65
Matt M's Avatar
Correct. Modified airbox with KN filter and our silicone coupler connects it to the turbo.
Old Oct 17, 2010 | 12:12 PM
  #66
Old Oct 17, 2010 | 12:14 PM
  #67
elecblue06's Avatar
daaaaaaayuuuuuuuum in for vidz
Old Oct 17, 2010 | 12:43 PM
  #68
And if he was running the extra port fuel injectors...how would switching the head matter AT ALL?
Old Oct 17, 2010 | 12:47 PM
  #69
Get out?
So the stock fuel system can support E85?
Well, in terms of performance
Old Oct 17, 2010 | 01:21 PM
  #70
RooTBeeR's Avatar
friggan wicked, waiting for vids tho
Old Oct 17, 2010 | 01:38 PM
  #71
09BlueBaltSS's Avatar
Get out?
Probly only because theyre only around 400bhp. It wont support 600bhp like people are wanting to do with big turbos iirc
Old Oct 17, 2010 | 01:52 PM
  #72
Iam Broke's Avatar
It's very interesting you are running the DI injectors and getting that power at 2800 psi, I guess I stopped too soon. I ran out of fuel at 2700 psi in the midrange and popped a limp mode on low fuel rail pressure and gave up the 100% E85.
Must be time to try it again.
How are you doing with hard starting cold? Mine was being a b!tch on E85, any clues?
Congrats!
Old Oct 17, 2010 | 01:58 PM
  #73
Matt M's Avatar
Yes, with the fuel pressure turned up and a stock turbo in place, it will support E85. I dyno'd 371whp uncorrected, and that is close to the limit.
Old Oct 17, 2010 | 02:01 PM
  #74
Matt M's Avatar
Congrats!
What do you mean by, "I ran out of fuel at 2700 psi?"
Old Oct 17, 2010 | 03:00 PM
  #75
Iam Broke's Avatar
My injector ms went to about 12 ms and it started breaking up a bit with a .90 PE lambda, When it got to 6500 in third and I let off it popped a CEL & limp mode for low fuel rail pressure. That was on E85 running 24 psi boost and 23* advance with the stock tranny ratio. My actual lambda showed .93 from the wideband during that pull. I was running the Trifecta base file with 2700 psi pressure >160% load.
I figured I couldn't get enough fuel into the DI window and backed off to 50% ethanol after that.
Here's a link to the post on HPTuners... I'm flowing ~31 lb/min VE when this happened.
http://www.hptuners.com/forum/showpo...&postcount=370
