Traction control , ABS Question
I was working on my ride a left one of the plugs for the ABS unpluged { Duhh !! } and took it for a test drive.. Whats the best way to clear the service ECS message Im getting ? I allready plugged it back in. Its in limp mod right now. I can drive on the tune with no problem at all. Any help appreciated. Thanks J.R.
all u should have to do is turn off the car and start it again... that's all i had to do
if not try unplugging the battery?
or go to autozone and get the code deleted
as far as limp mode, idk... abs light shouldn't be putting ur car into limp mode
I think it has to do with the traction control. Its only in limp mode when the traction control is on. When I push the button for the tune its OK. My scanner only reads OBD2 codes not the ones related to traction control. I might try the battery disconnect tonight. I get Low Traction warning. Thanks for your input
