Traction control , ABS Question
Old Apr 3, 2010 | 12:37 PM
mongorat427's Avatar
I was working on my ride a left one of the plugs for the ABS unpluged { Duhh !! } and took it for a test drive.. Whats the best way to clear the service ECS message Im getting ? I allready plugged it back in. Its in limp mod right now. I can drive on the tune with no problem at all. Any help appreciated. Thanks J.R.
Old Apr 3, 2010 | 12:52 PM
Hawaiian Whore's Avatar
all u should have to do is turn off the car and start it again... that's all i had to do
if not try unplugging the battery?
or go to autozone and get the code deleted
as far as limp mode, idk... abs light shouldn't be putting ur car into limp mode
Old Apr 3, 2010 | 12:59 PM
I think it has to do with the traction control. Its only in limp mode when the traction control is on. When I push the button for the tune its OK. My scanner only reads OBD2 codes not the ones related to traction control. I might try the battery disconnect tonight. I get Low Traction warning. Thanks for your input
Old Apr 3, 2010 | 01:21 PM
mron0903's Avatar
you might of damaged the wire if it was pulled out
Old Apr 3, 2010 | 07:44 PM
The connector was unplugged. I reconnected it after after the abs warning popped up. I disconnected the battery for the night
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
Extremespeed
Sep 29, 2015 04:34 AM
Coballin13
Sep 25, 2015 08:43 AM
