Traction Control (ESC) Out of Control
Old May 2, 2024 | 04:10 PM
ProfDNS's Avatar
I'm having yet another interesting issue, this time with the ESC. It only activates when going around right bends (not right turns) and going over 80km/h. I've had a ball joint replaced and did an alignment for a total toe of 0.15. Camber -1 degree on both sides. Before the alignment, it felt like the car would drop the left side into the ground and shoot me off to the right, but no ESC activation. Now I believe I still have a slight tire issue with the previous, but moreso now the ESC always activates even if I turn it off on the dash. Could this be a wheel speed sensor issue on the right tired? Going over left bends, I can go as fast as I went with absolutely no issues.
Roundabouts, I would figure the ESC would activate or tire grab - no for the ESC, tire grab is very light (very dependant on road being smooth or not), and I can fly and change directions for the most part with no issues. I also get torque steer if I go into a higher boost on acceleration.
Old May 2, 2024 | 08:39 PM
blu3_v1p3r's Avatar
Did you do any suspension recently? I had ESC problems after I replaced all my front suspension. In straight line it was fine at low speeds, but if I gave it the beans it would torque steer, and it would go wild. Mine was only like that for 2 drives, one from the shop where I did the work, and then to the shop to do the alignment ,and all my problems were solved.
Old May 3, 2024 | 11:21 AM
ProfDNS's Avatar
Well last year, I had camber bolts installed to lessen the camber as it was sitting just a bit over -2 degrees and it was eating up my tires on the inside. Otherwise it's just the ball joint, and with the summer tires back on, they were on the rear so those should be fine. I'll upload a copy of the current alignment specs, maybe I'm missing something.
What I do know is the front sway bar moog bushings are getting pretty floppy. I have to contact Rock Auto about that for the limited lifetime warranty.
Old May 7, 2024 | 04:15 PM
ProfDNS's Avatar
I keep forgetting to bring my copy of my alignment in so I can scan it. Pretty sure it's still off that's causing it. At least the sway bar bushings are being shipped.
Old May 10, 2024 | 04:26 PM
ProfDNS's Avatar
Should have looked at this closer, they didn't do a good job, but it shouldn't be causing my level of issue.
While I price out another shop, should I go 0 camber and 0.1 total toe, or just fix the left tire camber down to 1 degree?
Old May 10, 2024 | 07:00 PM
blu3_v1p3r's Avatar
I just have them try and get mine back as close to stock as possible. I have referenced this picture from Maven pretty often. FE5 with QPA is the LNF.
Old May 13, 2024 | 12:03 PM
ProfDNS's Avatar
Thanks for providing that!
While I was out yesterday, the service traction control message came up while I was on a highway, about 50 minutes into my drive. With that malfunction, while the tires still are a bit grabby, it wasn't nearly as bad of a correction that's needed. Parked the car for a few minutes, which made it go away, but decided to turn it completely off manually (hit the traction control button, then press and hold until message confirmed). I would say the problem is now 85% esc and 10% tires/5% alignment?
Old May 14, 2024 | 08:14 AM
It could be a wiring/wheel speed sensor issue, but I'd definitely start with the easy stuff like an alignment and visual inspection of the wheel bearings and the ABS sensor connector.
Old May 14, 2024 | 11:40 AM
ProfDNS's Avatar
The wheel bearings look good, including the wiring - oddly enough I've never had an issue with ABS. The left tire will need to be put to 1 degree flat and I'll be putting the new moog bushings in this week and try again. My concern is the speed senor, the location is not ideal.
Old May 14, 2024 | 11:55 AM
The ESC takes some info from the ABS iirc, I wonder if the yaw sensor under the passenger seat is messed up.
Old May 14, 2024 | 09:52 PM
ProfDNS's Avatar
It sounds like I'll need one of those more expensive scanners to individually look at the voltages of the sensors. Other than HP Tuners, I only have the (paid) Torque app which doesn't do anything outside the engine.
Old May 30, 2024 | 11:12 PM
ProfDNS's Avatar
Update: I cleaned the connector with some electric spray, didn't seem like it was dirty, but overall I think this and re-aligning that tire back to 1 degree seems to have fixed it. Still a bit more testing, but I didn't disable the LSD and was driving it fairly hard into corners. Only shock loaded once or twice, I think mostly because of the shitty road I was on. Fingers crossed that this was the issue!
Alyssa Balmes
May 17, 2016 01:34 PM
QuickSilver_SS
May 19, 2015 04:58 PM
m0ore4ustin391
May 31, 2013 12:35 AM
bobbyhill31286
Oct 1, 2011 12:29 PM
JT-KGY
Autocross and Road Racing
25
Oct 15, 2009 04:01 PM
