Tranny...fail and nosey tech......smh
And for the love of all things good learn how to spell warrAnty!!!
Wow dude, calm down, no need to get them in a bunch.
I was just a the dealership with my Trifecta tune and a check engine light. The car was scanned YESTERDAY and replaced a bad MAP sensor with NO ISSUES. My car has been scanned two or three times since my tune has been installed. Then again, I do live in a BIG metropolitain area where folks are too busy making money and sticken and moving so they don't have time for petty BS like trying to void crap.
Trannies shouldnt fail in this car. if your having issues it really should be covered anyways. I just thought it was pretty rediculous that you couldnt believe a tech at a dealer was nosey.
I had 13000 miles on my Cobalt SS/SC for 3 years before I traded it, never had an issue with the tranny which is the same in these cars. I heard ppl said they had them failed because obviously they don't know how to shift properly. Its too so bad, I'm now hearing recalls on the SS/SC's dealing with the CAT causing the car to lose power and the resorvior being cracked, which I'm assuming they meant the coolant.
If you dont have the stealth tune and they scan the ecu your probly screwed. Otherwise I doubt they would send the calibration files in for examination in your case. Maybe if it was a catastrophic failure
let me find that internal gm letter....
Here you go, that magnuson warranty act wont work with a aftermarket tune
https://www.cobaltss.net/forums/general-cobalt-68/gm-now-looking-aftermarket-tunes-114905/
Repairs to transmission, transfer case and/or other driveline components where a non-GM engine calibration has been verified are not covered under the terms of the New Vehicle Warranty.
You increased the power beyond what GM felt was a safe level. Transmission ends up in pieces. Pretty straight forward connection there.
Possible. It's probably an inner cv, unless it's more pronounced when turning, then its an outer. The way he describes it it sounds most likely. It clicks during accel and decel...so does this mean ALL the time...since you are always acceling or deceling, unless idling. I bet he doesnt hear it once he reaches over 20-30 MPH.
I would just upgrade the axels and do it myself, if GM doesnt cover it, if it is the axles.
Regarding tune, in this case, I say not much of an impact, if it is the axles...more like a shitty driver, doing shitty launches...shitty, shitty, shitty
What about going 70mph with cruise control on there chief???
Have the dealer re-torque your axle nuts. The big ones on the end of the hub. My clicking stopped after that.
Really? ahhaa you so funny, maybe you should read the definition of idling
and here you go too... cruise control
Thats going to be your debating point? Seriously? Your going 70...so technically you are accelerating. No you're not accelerating, beyond 70, but your car has accelerated from stand still.. Add something helpful instead of criticizing the use of acceleration. If this were grammarss.net we might give 2 *****...maybe even 3, but it's not...chief
Idling - To run at a slow speed or out of gear. Used of a motor vehicle...
Now I imagine in CC your car is in gear correct? And in your original post regarding 70...70 isnt technically slow. Read your own posts of defintion before you criticize...
Anyways give some input on cars, not words, Webster.
Last edited by steven6870; Feb 21, 2010 at 06:09 PM. Reason: Automerged Doublepost
I don't even know how to respond to this. SO MUCH FAIL in one post.
I get the same noise for some reason right now; clicking noise coming from what sounds like the front end, but I only hear it once I go above 20mph and then after 40 it seems to go away since the wind noise drowns it out.
This noise is coming whether I'm in gear or coasting in neutral. Any thoughts?
^^^Check you axles. Find an open parking lot, place car in reverse and drive backwards. Accelerate and deccelerate alternately. If the noise is more pronounced then its the inner cv. If you do the same test, but turn ur steering wheel to the left and right and its more pronounced then its the outer cv joint. If these tests dont help determine the issue, im betting on some extra play or backlash in your differential gears, but considering ur not even in gear and it does it, makes me thin its more like an axle issue
I could be completely wrong but with my past cars it had its always been one of the three choices i proposed.
Understandably so. If it's powertrain related, I would completely agree. Axle tick, I'm not so sure about. Hell, G35's are having nasty problems with this, a majority of the time they were improperly lubed from the manufacturer.
