Trans fluid
Old Nov 18, 2010 | 03:15 AM
raynrishad's Avatar
Trans fluid
Anyone know what type, how to check how full it is, and where to fill it at? I'd look in my owners manual but it's for an 07 SS -_-
Just did the clutch on my balt and now it's a wee bit low on trans fluid. Any help would be awesome.
Old Nov 19, 2010 | 10:48 AM
SSlobalt's Avatar
It will be some kind of LSD lube. Call your dealer and ask.
Old Nov 19, 2010 | 10:52 AM
BYT*SS*TURBO's Avatar
^That's wrong. Ours is a closed diff and that's a common mistake people make. Either Dealer only or Redline MTL. I just tried the MTL and I like it so far.
Old Nov 19, 2010 | 10:56 AM
SSlobalt's Avatar
My bad. I only have 13K miles, so I haven't even started looking into this. That's why I suggested calling the dealer. That's what ima do.
Old Nov 19, 2010 | 11:05 AM
Honestly, if I hadn't researched this all last week, I prolly would've said the samething LOL
Old Nov 19, 2010 | 11:23 AM
Iam Broke's Avatar
Red Line MT-85 is a good match for the LNF fluid. Same viscosity as Castrol SynTrans, which is what the LNF GM fluid is. It is also a GL-4 fluid same as stock. MTL is a bit thinner and MT-90 is thicker but both GL-4 specs. Do not use a GL-5 NS or GL-5 fluid in our trannys. It was designed for GL-4 fluid.
Like BYT posted, we have a sealed diff.
Old Nov 19, 2010 | 11:30 AM
themacguy's Avatar
This> https://www.cobaltss.net/forums/driv...thread-230048/
Old Nov 19, 2010 | 11:46 AM
fakameanrepresent's Avatar
so how oftern should we change it? by years, or by miles? what if you never drive your car? i put like 6600 miles in one year and seven months.
Old Nov 19, 2010 | 11:51 AM
Chevycobaltss3's Avatar
Id check for leaks when ever possible cracks and so forth. Fluid wise, depends on the person. I change mine every 25k miles but I don't think u need to till 100k or so. I am about 80% sure not 100% lol.
Old Nov 19, 2010 | 11:53 AM
WSFrazier's Avatar
Just use the GM stuff, it's on CED.
Old Nov 19, 2010 | 12:07 PM
also, which onw we suppose to use? redline MT-85 GL-4 or 75W90 NS GL-5? no one really say which one to use.
Old Nov 19, 2010 | 12:13 PM
MTL or MT85.
thanks, i will just stick with MT-85 or GM fluid.
Old Nov 19, 2010 | 12:14 PM
Where cn I get mt-85
Old Nov 19, 2010 | 12:19 PM
redline website, or just google it.
Old Nov 19, 2010 | 12:29 PM
Iam Broke's Avatar
Jegs stock it.
Old Nov 19, 2010 | 02:36 PM
raynrishad's Avatar
I eventually had my uncle dig it up because I needed the info pretty fast, sorry guys. Which was good cause for some reason ALL the dealership was pulling up was the LSJ fluid -_- Focking dealership pulled the trans out, looked at my clutch told me it was fried. They let out almost a full quart of the trans fluid doing it and didn't fill it back up and I beleive the full capacity is just over a quart. jackasses.
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
Tupp
Sep 29, 2015 11:07 PM
Sep 27, 2015 08:53 PM
