Treadstone intake
Old Nov 5, 2011 | 09:02 AM
C_A_D88's Avatar
Treadstone intake
Who's got one, how's it work, any issues?
Any thing positive or negative to say bout it?
Old Nov 5, 2011 | 01:02 PM
SSlobalt's Avatar
So many intakes, so little time.
Old Nov 5, 2011 | 01:22 PM
RyRidesMotox's Avatar
I have one. Have had all my treadstone stuff on for about a year now. No problems at all. Fitment was accurate and install was pretty easy. One thing to note... The PCV line going from the valve cover to the intake needs to be removed from the valve cover and routed to the Treadstone intake with a rubber hose, or whatever you want to use. Apparently most intakes come like that... The line is used to recirculate the BPV's pressure for the turbo, so don't just remove it.
Old Nov 5, 2011 | 05:38 PM
FrossB's Avatar
Thread Killer
Got it. Love it. Install is easy and it looks awesome
Old Nov 5, 2011 | 05:50 PM
matt638's Avatar
hahn ftw lulz
Old Nov 6, 2011 | 02:46 PM
C_A_D88's Avatar
How would I go about
Doing this?
Old Nov 6, 2011 | 02:52 PM
Chevycobaltss3's Avatar
heres my 2 cents. i have used everything out there, installs tuning and ect. So far the best result have been with treadstone. NO joke. Nothing against any other vendor but zzp charge pipes are always different they are never the same, and ive done quite a bit installs. intake wise i say do it...
Old Nov 6, 2011 | 03:25 PM
C_A_D88's Avatar
How do I go about running the PCv line? And also if it doesn't come with the honey comb should
I get it? And how do I get that installed in the intake?
Old Nov 6, 2011 | 04:57 PM
yes get it, if you look at the ste itll explain in detail on how to install the honey comb..
Old Nov 6, 2011 | 06:05 PM
Fuel line removal tool to take off the stainless line coming off the back of the valve cover. Then you get a section of rubber hose and some hose clamps to connect it. Your good after that... Or if you want you can get an oil catch can. This does the same thing but has the added benefit of removing any oil that might get into the intake.
Old Nov 6, 2011 | 06:41 PM
C_A_D88's Avatar
That sounds like a plan any good reviews on any particular catch can?
Old Nov 6, 2011 | 06:43 PM
matt638's Avatar
mpx one looks nice
Old Nov 6, 2011 | 09:52 PM
Did you tune with the honeycomb as well? When I first got the kit on my car people didn't believe me n term that it was real clean (compared to others) STFTs and LTFTs right out of the box.
Old Nov 6, 2011 | 10:14 PM
I have tuned a few. On my car no.... But yea truth be told there **** to me is the best.... Stft and ltft are clean
I think I'm gonna order one though for my car I dunno yet.
Last edited by Chevycobaltss3; Nov 6, 2011 at 10:14 PM. Reason: Automerged Doublepost
Old Nov 7, 2011 | 09:58 AM
C_A_D88's Avatar
Do I need a tuNe to run the intake with no issues?
Old Nov 7, 2011 | 10:05 AM
Well the intake will throw trims a wee bit. But in order to get best results a tune is needed and recomended.
Old Nov 7, 2011 | 10:46 AM
C_A_D88's Avatar
What does te fuel trims Being skewed a bit do?
Old Nov 11, 2011 | 05:07 PM
C_A_D88's Avatar
So I'm installing my treadstone intake and fitments not what it's supposed to be, the small Angled tube that goes to the filter is either bent wrong or to long, I have to shove it way inside the filter to get it to fit... Any ideas before
I cut that piece shorter? As if I leave it how it is it touches the inside of the filter.
Almost like that piece is bent wrong, to long or the filters to big...
Get back to me asap thanx
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
OrangeCoba
Sep 25, 2015 06:06 PM
