Trifecta gets it done: Fuel tables unlocked
Old Nov 10, 2009 | 11:10 PM
  #126
beast10007's Avatar
Originally Posted by conny3737
that definitely peaked my interest. Vince you'll have to give us a heads up on how the meth tuning is going to see if it's going to be a worthwhile mod.
yes I would like to know more about this...I have always wanted to run meth!
Old Nov 10, 2009 | 11:48 PM
  #127
RBC's Avatar
RBC
Originally Posted by VinceTrifecta
We could give you a third tune profile that adjusts the tune for on the spray vs. off the spray
I thought you could do this but when I asked CJ he said he passed the question on to you and he said you told him it could not be done. Maybe I will give you call later this week so we can talk.
Old Nov 11, 2009 | 11:26 AM
  #128
buellfooll's Avatar
Next thing you're gonna need a 10 position rotating switch to handle all the options!
Old Nov 11, 2009 | 06:54 PM
  #129
Tomtwtwtw's Avatar
I'm sure he can find a way to key it into the a/c direction knob. There's a good 20 stops on that thing!.
Old Nov 11, 2009 | 07:02 PM
  #130
elecblue06's Avatar
manual boost controller
Old Nov 11, 2009 | 07:11 PM
  #131
marcusicp's Avatar
How many profiles can our computers hold? This is very good news indeed!
Old Nov 11, 2009 | 07:48 PM
  #132
JPizzle's Avatar
Very good point Marcus. Exactly how many can our cars hold?
Old Nov 11, 2009 | 08:02 PM
  #133
1badBlueberrySC's Avatar
I don't understand why you would not want to spray all the time... a cooler intake charge is good all the time whether WOT or not.
If you do a basic kit set at 10psi your not going to be on it unless you go WOT anyway.
Eh... just my thoughts
Old Nov 11, 2009 | 09:07 PM
  #134
SeanEE89's Avatar
subscribed
Old Nov 11, 2009 | 10:15 PM
  #135
Blk08coupe's Avatar
What I would like to now is with these tables unlocked, can a stock turbo TC or swapped turbo TC make 350whp to 7k rpm? I am not looking for so much as a huge hp number, but a wider power curve. So a slightly bigger BB turbo to extend the rpm range and make more useful power under the curve is what I would be looking for. I'd like to have a 350whp DD that can safely pull to 7k and actually make power there instead of run out of steam.
Old Nov 11, 2009 | 10:42 PM
  #136
slowbalt84's Avatar
swap on a 16g and call it a day lol
Old Nov 11, 2009 | 10:54 PM
  #137
HunterKiller89's Avatar
swapped turbo TC can...stock turbo will die off before that.
Old Nov 11, 2009 | 11:06 PM
  #138
mkriebs's Avatar
Why do people recommend the 16G? Has anyone seen the K04 side by side with the 16G? Because it is very similarly sized. Also, SRT's have what is called a small 16G (versus an Evo 'big' 16G), and it runs out of air at about 5k rpm. The EVO 'big' 16G runs out about the same place the K04 does.
**This is just from my experiences and my research. Someone might be able to run the damn thing ragged and push some more, but w/e.
Old Nov 11, 2009 | 11:09 PM
  #139
slowbalt84's Avatar
i heard from a little birdie that a company is working on a 440hp rated 16g swap for our cars. and im going to be first in line if their numbers are good
  #140
slowswap's Avatar
16g is not a good size for making more power. GT2876r or larger for more power.
Old Nov 11, 2009 | 11:13 PM
  #141
slowbalt84's Avatar
^ fail. A 16g with 20g parts can make 450whp
which is rated higher or about the same as a gt28
Last edited by slowbalt84; Nov 11, 2009 at 11:13 PM. Reason: Automerged Doublepost
Old Nov 11, 2009 | 11:14 PM
  #142
slowswap's Avatar
I never said a 16g hybrid. I said a 16g.
Old Nov 11, 2009 | 11:17 PM
  #143
slowbalt84's Avatar
not being a ball buster just saying it's stilla 16g
everyone likes to nuthug the garrett turbo but mitsubishi makes some bitchin turbos
Last edited by slowbalt84; Nov 11, 2009 at 11:17 PM. Reason: Automerged Doublepost
Old Nov 11, 2009 | 11:19 PM
  #144
mkriebs's Avatar
I actually hate Garret turbos. They were good... 5 years ago. PTE or Airwerks is where the technology is at nowadays.
And, you didn't say a 16G hybrid. I was talking about a 'small' or 'big' 16g.
  #145
slowswap's Avatar
They're not that great. They work well for factory applications because they can take a beating, but there not the most efficient turbos out there. People nut the Garrett's because the ball bearing provides a slightly faster spool and on a 4 cylinder, a larger power band is very critical unless you're an all out drag racer.
Old Nov 12, 2009 | 03:47 AM
  #146
troof. ZZP had a good write up explaining why the BW turbos are superior to equivalent garrett turbos. And yea, mitsus are kind of near the bottom of the barrel in performance, but there incredibly reliable.
Old Nov 12, 2009 | 03:48 AM
  #147
mkriebs's Avatar
BW and PTE are on the top of the game right now. They are very similarly equipped.
Old Nov 12, 2009 | 07:29 AM
  #148
damien's Avatar
I like FP units. They're quite pricey but well worth it IMO.
Old Nov 12, 2009 | 01:00 PM
  #149
Terminator2's Avatar
Unless you are using the big wheel 16G that comes in the EVO's you will be very disappointed when it makes only 315 whp at 25 psi.
Old Nov 12, 2009 | 02:30 PM
  #150
slowbalt84's Avatar
sorry. I mean a 16g with a 20g compressor wheel. better?
