Trifecta switchable tune update!
#101
I ordered the new selectable tune, but I am still not sure of a few things...
If I decide to go with the Comp. Mode on=agressive tune and Comp. Mode off=stock tune does the stock tune still have the learn down enabled? Or is the learn down disabled with either option? In terms of a stock tune, will this be exactly the same tune that came on the car when I purchased it or is it just more of a GM Stage Kit-Superchips type moderate tune? I'm sure I will find all of this out on Monday when I get the phone call, but I am too impatient to wait!
#102
Vince, I'm sold - on the fact you have a "automatic push button tune"...
two questions:
- is it possible to have a different tune for each button -
cruze control "on" - runnng 23/26 psi
comp mod "on" - running 28/30 psi
both buttons "off" - running stock tune w/20 psi
- is it possible to have the same setup you have for LS1 running NOS using the "buttons"
turning on NOS and/or METH inject at a set point during the powerband??
two questions:
It is certainly possible we just need to find a usable output on the ECM.
LC settings are unchanged
I don't have any dyno numbers on the +2-3psi tune but I will say that the "beast" tune makes about 30HP over our "classic" LNF tune, which made about 50HP over the stock tune.
Last edited by VinceTrifecta; 07-26-2009 at 01:11 PM. Reason: Automerged Doublepost
#105
However, performance tunes (including ours) effectively disable it by asking for a power level that is higher than the engine is capable of producing. I call this "learning it up".
But, to run it with the stock tune is to run it with the stock commanded power values which means it will deliver stock power. Hence, when the stock tune is selected, it will "learn down" to stock power level.
#107
they are already having fueling issues with the stock injectors? E85 would require 30% more fuel to run the same as gasoline. and most likely a return style fuels system.
#108
With the new selectable tune, do you basically get the stock setup and the agressive tune? I was under the impression that we were getting 2 NEW tunes from what i've been reading. I guess i'm just a noob to the whole "tuning" idea. It would be nice to have a GM stage kit type tune with your traction control on, and the agressive tune tied to the comp. mode. Is that at all possible?
If you add another mod after your tuned (such as a catback exhaust), do you have to get retuned? If so, how much would that cost for a re-tune?
#109
#112
At what hp is the new Trifecta tune running? Can a slightly lower output be accomodated for someone who doesn't want to worry about clutch slipping and what hp range would that be?
#113
with full bolt ons you can look at 335-340whp and 375wtq... thats from my experiense cuz i did 322whp/365wtq with the stage one... im spining my 235 wheels on 2nd like a mother ******....
#114
Quote:
I was thinking in the same lines.. but change out the whole fuel system, to a high output aftermarket pump, filter, lines, injectors & dual tanks (93 and/or 100/114)??? the system is around $3800... or use something like the C6 uses and have Vince write code for the increased fuel system..
#115
#122
Now this depends on how you are driving. If Im in third under 60mph and stab the gas down I will get a little slipping for about 300rpms then it catches and holds fine. First and second i havent experienced any slipping mainly because the tires come unglued first. If I roll onto the throttle though I usually see no slip.
This is probly the reason GMS1 only makes 340tq. They wanted to make sure that the clutch was not gonna slip no matter how you were beating on it
#123
1st and 2nd gear.... slow off the line is fine... if you romp it you squeal tires (unglued lol) a little bit then SWOOSH into third.... which does slip a bit... dunno, i guess its just something with 3rd gear and at what RPM's your at?
#124
Come to think of it. I cant really think of anyone that has had a clutch failure other than Cardelino18, even though I think his had a defect.
