Turbo flutter/surge?
Old Apr 2, 2012 | 10:37 PM
TX.SS.TC's Avatar
I just got a new LNF dropped in my 09 after the last one blew, now after about 500 miles on the new engine I seem to getting a LOT of flutter/surge when I let off the throttle. I went to work today and rolled into WOT a couple times in third and everything was fine but when I got back into my car after work it was making the flutter sound. At any low PSI it would make a "shuttering/hesitant" sound when I let off the throttle and any high PSI it would just make a very loud sound of just air blowing out, no BPV noise at all. Performance seems the same though, could it be my BPV? My turbo? Any help is greatly appreciated
Old Apr 3, 2012 | 02:35 AM
TX.SS.TC's Avatar
Old Apr 3, 2012 | 09:16 AM
TX.SS.TC's Avatar
Anybody?
Old Apr 3, 2012 | 09:34 AM
Cobalt_Daddy's Avatar
i don't know but sounds like a sensor of some type
Old Apr 3, 2012 | 09:56 AM
TX.SS.TC's Avatar
I don't know, it hasn't lost boost, went into limp mode or anything
Old Apr 3, 2012 | 12:42 PM
TX.SS.TC's Avatar
Old Apr 3, 2012 | 02:17 PM
Wangspeed's Avatar
Start with both MAP sensors, CAI, and MAF locations. Also worth double checking the wastegate solenoid vacuum lines.
And read the codes!
Old Apr 3, 2012 | 02:20 PM
MastaShaKe_88's Avatar
did you put the mods back on it?
Old Apr 3, 2012 | 02:37 PM
1SLOLT1's Avatar
What tune if any? GMS1?
Old Apr 3, 2012 | 02:46 PM
TX.SS.TC's Avatar
All the mods in my sig are on the car and put back on by the dealership with my new engine
Old Apr 3, 2012 | 03:09 PM
TX.SS.TC's Avatar
And read the codes!
What should I be looking for when checking the MAP sensors, MAF, and CAI? Could it be the BPV too?
Old Apr 3, 2012 | 03:49 PM
TX.SS.TC's Avatar
And the weird sounds happen ONLY when I let off the throttle while in boost
Old Apr 3, 2012 | 03:55 PM
ford's Avatar
Check the MAP sensors to ensure they are seated correctly. If they had the turbo off maybe they took off the BPV and tore it? My brother's car had ton's of flutter from a torn diaphram in the BPV.
Old Apr 15, 2012 | 04:08 PM
oli_ss's Avatar
GM just changed my turbo on warranty last week and it seems like im having flutter when doing short WOT... is the BPV on the turbo or is it separate? should i be upgrading to Forge with better springs?
Old Apr 15, 2012 | 04:11 PM
Chevycobaltss3's Avatar
What blew in the engine ? And if its fluttering was the.tune revise and changed. Also check for a boost leak or vacuum leak
Old Apr 15, 2012 | 04:23 PM
silverSS08's Avatar
Bypass valve is on the Turbo. Very easy to remove and check for tares. I think its 3 bolts, its a tan colored piece wit a tube clamped into the center of it.
Old Apr 15, 2012 | 04:48 PM
gotboost?17's Avatar
Nothin Stock
i would start with a new bpv
Old Apr 15, 2012 | 04:50 PM
JacBlackSS/TC's Avatar
check the bpv and the vacuum lines, i had work done on my car and they installed the lines wrong. but you are lucky they replaced your motor on your modded car, smh gm left me high and dry
Old Apr 15, 2012 | 04:57 PM
oli_ss's Avatar
you can remove it from above or you gotta go from under?
Old Apr 15, 2012 | 11:28 PM
AARON-SS-TC's Avatar
i bet its a boost leak, and its probably the BPV..get a forged one
Old Apr 15, 2012 | 11:43 PM
TheTruth7's Avatar
My car has a new BPV and it randomly continues to have this problem as well. Wont boost passed 6 and sounds like a turkey gobble. Then it will randomly go away. Idk what is.
Old Apr 15, 2012 | 11:45 PM
check your vacuum lines and your intercooler couplers or intercooler itself...there is a leak...mine is doing the same thing right now except it fully boosts afterall the gobble gobble flutter crap...lol
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
