Turbosmart BOV Problem
Old Apr 30, 2011 | 09:17 PM
BooSSted's Avatar
So I just installed my Treadstone S3 kit with a Turbosmart RacePort BOV. Everything went on fine and I followed RyRidezMotox's walk through.
When I started the car, everything seemed fine. Idle was good etc. When I revved the engine to see of the BOV was working, all I got was flutter. The BOV isn't opening at all.
Now my question is, how are the vac lines supposed to be run? I ran the line from the stock BPV to the BOV and I "T'd" the vac line from the old lower charge pipe with the other vac line on the manifold.
Anyone have any ideas what I may have done wrong?
Old Apr 30, 2011 | 10:07 PM
09BlueBaltSS's Avatar
Ive heard of people running the bov straight to the vac port on top of the manifold. Then loop the top port of the bpv solenoid to the port on the left side(this would bypass the vac tank)
Old May 1, 2011 | 02:38 AM
BooSSted's Avatar
Pics? Can't picture the parts you're referring to.
Old May 1, 2011 | 03:31 AM
ericgt79's Avatar
lol you have to hook up the vac line you cant bypass that step
Old May 1, 2011 | 09:12 AM
08SStc's Avatar
you have too stiff a spring in it, I also have the turbosmart race port and it comes stock with i think 18in hg setting. IE rarely open on a cobalt. I had to order the spring kit and am running at the 12in hg setting, still occassion get quick flutter the pooossshhh, but rarely so im not goin lighter
Old May 1, 2011 | 09:29 AM
Chevycobaltss3's Avatar
Wrong not to stiff i have the billet hahn turbo smart bov. U need to t into the direct vacuum source on thr intake manifold "middle of the mani"... Mine works fine..
Old May 1, 2011 | 10:47 AM
BooSSted's Avatar
Ok, I have the line from the stock BPV running to the new BOV.
So the line on the left of the solenoid on the manifold goes directly to the new BOV. line from the top of the solenoid is now t'd into the direct manifold line in the middle of the manifold and the line on the bottom of the solenoid is left untouched.
Is this right?
Old May 1, 2011 | 10:54 AM
peachpuff's Avatar
Connect the bov directly to the manifold, bypass the solenoid and block one of the lines that goes from the solenoid to the ic pipe like i mentioned here https://www.cobaltss.net/forums/5744524-post6.html
Old May 1, 2011 | 11:15 AM
BooSSted's Avatar
If i do it that way, I am going to have 2 open ports on the solenoid. Do I just block them both off? My cold pipe does have the vacuum port by the MAP, so it is basically blocked off the same as yours. what did you do with the line that used to run to that location?
Old May 1, 2011 | 11:17 AM
T into the vacuum port on on the intake itself. Get rid of the vacuum tank and the other line will go to the bottom part of the solonoid on the intake.
Old May 1, 2011 | 11:25 AM
BooSSted's Avatar
Vacuum tank? I need pics!!!! Lol
This is what mine looks like right now. Left port goes to the BOV. Top port is T'd into the Manifold line and the bottom one is left alone.
If I T into the manifold line for the BOV. What do I do with the 2 ports on the solenoid?
Old May 1, 2011 | 11:48 AM
BooSSted's Avatar
In this picture, do you just have the Top port and the Left port on the solenoid looped together?
I'm not too anxious to go outside and just start switching lines around without knowing for sure how they are supposed to go, haha. I don't want to eff something up.
That picture is blocking those 2 lines, so I can't see if it is just one line looped from one port to the other.
Old May 1, 2011 | 12:27 PM
BooSSted's Avatar
Just hooked it up the vacuum line one the manifold..... Still nothing
Old May 1, 2011 | 12:31 PM
BooSSted's Avatar
Here's another question. I just took the BOV off and I can't even push it open with my hands.... Should I be able to do this?
Old May 1, 2011 | 12:35 PM
05Slowline's Avatar
i would think not the springs are about 5-8 inches long compressed into an inch and a half so
Old May 1, 2011 | 12:37 PM
BooSSted's Avatar
I find it hard to believe that the air pressure in the charge pipe is greater than what I can apply with my hands....
Old May 1, 2011 | 12:38 PM
05Slowline's Avatar
well no offense but you can't seem to even hook up a bov to a boost reference source lol
Old May 1, 2011 | 12:54 PM
peachpuff's Avatar
That line was connected to the solenoid and its disconnected now.
Don't worry about the loop, i just did it to cover up the ports until i got some vacuum caps. All 3 ports from the solenoid are disconnected for their sources(bov/manifold/ic pipe).
Old May 1, 2011 | 01:04 PM
BooSSted's Avatar
So disconnect everything from the Solenoid and block off the lines?
I just got the BOV working by connecting it directly to the manifold. It opens under boost, but I am still getting flutter when not under hard boost. Like when I shift at say 3000rpm it flutters.
Old May 1, 2011 | 01:06 PM
05Slowline's Avatar
Isn't there somewhat of an adjustment on those, thought there was. If not prob have to change springs.
Old May 1, 2011 | 01:15 PM
BooSSted's Avatar
Not that I can see....
Old May 1, 2011 | 01:19 PM
05Slowline's Avatar
Some of them have soft/hard adjustments on them some don't i'd say change springs or w/e if not
Old May 1, 2011 | 02:23 PM
BooSSted's Avatar
Just went for a drive and now the car won't boost.
**** it, Stock BPV is going back in......
Old May 1, 2011 | 07:21 PM
08SStc's Avatar
you do have the RacePort BOV from Treadstone right? Im telling you the spring is to stiff. I had this problem too. These DBW throttle bodies dont close quick enough, so we dont create vacuum quick enough to open the heavier springs without flutter
Old May 1, 2011 | 10:49 PM
BooSSted's Avatar
Do you have the same one?
Where and what spring did you get? The spring being too stiff does make sense.
