Turbosmart BOV Problem
you have too stiff a spring in it, I also have the turbosmart race port and it comes stock with i think 18in hg setting. IE rarely open on a cobalt. I had to order the spring kit and am running at the 12in hg setting, still occassion get quick flutter the pooossshhh, but rarely so im not goin lighter
Can you post some pictures of how you have your vac lines set up? I notice you ran them like mine in your post on the previous page. Did you relocate your maf sensor?
Ok, well if you ran them like mine, I can assure you that it should work. Is your MAF relocated? If it is then it is most likely a tuning issue with the WG duty cycle or MAF being in the pressurized pipe now. If the MAF is still in the intake (stock location), when you shift your car will read a richened state and also a loss of metered air. This will throw P0100 (I think, could be P0101 also I cant remember) which is a MAF code and throw your car into a limp mode. Even if the code is turned off it still effects your car. Before I relocated the maf on mine, it would run like a raped ape for like 15 minutes then it would suck nuts. I PM'd you my number, call me when you get home from work, I'll help you the best I can.
Call Jason and have him switch it out for you with the original he sent you. I told him about the problem before you bought yours. He should send you a new one. You might have to pay for shipping back to them but other than that they should get you another one out. I can guarantee you with nearly a 100% certainty that the MAF is freaking out.
How does your BOV work? Any shudder at all when shifting at low RPM??
Oh, and I did throw the P0100 code, so I know the MAF is one of the issues with drivability. My main concern now is how well the BOV works....
#36
I just sent him an e-mail about the problem, I'll wait and see what he says.
BooSSted and I are both going to be turbo swapping in the near future, not so near for me now, but it will happen. I'm not sure why you are trolling on this particular thread but at least stick it out til the solution is found so you can make an educated decision before you jump to your conclusion.
#37
Yea at low boost like 5psi or less it flutters a little. The stock BPV probably is guilty of this too but you just can't hear it. I have never heard a bov that doesn't flutter a little at low psi hold more than 12psi +/- a few... and visa versa, I don't know of any meant to hole 24-26lbs out of the box that don't flutter a little at low boost and engine speeds. Its a trade off. Also look into Hp tuners, Vince is not a fan of the BOV. Term set up my car amazingly, there are a good amount of HP tuners on here that can set you up very well.
#39
I had a vent to atmosphere bov that I "T" in along with the stock bpv. So that makes me qualified to give an opinion on atmospheric bov's. Ran like **** and stuttered when getting on it when shifting gears fast. If you plan on going bigger turbo then gather all the parts and once you have everything put it all on at once. I had a mutilated bpv diaphragm so I wanted to try to use a bov to prevent that problem, now I have the forge bpv and everything runs great.
Keep my number if you have any problems let me know.
