TurboTech STOP mounts
cmiller and d-mac have optimal drag setups....they both run powell mounts last i checked.......cmillers travel limiters help a ton too.
yeah typo on my part. my bad...not nut swinging.. i believe its a superior product and not because john powell made it. but im going to stop in this thread before i get banned for bashing. might aswell say the *** sway bars good to huh? not to mention how much warping ive seen and how it causes snap oversteer? great product....btw wounder why it got pulled for a soon to come chrome moly design....bet its VERY similar to the powell bars.
17 degree rotation.
17 degree rotation.
because you are being a dick, I will point out you have not tried Powell Mounts so wtf do you know? Usual disclaimers, usual bs.
Oh I have had experience with both mounts btw. And you clearly dont understand why a smaller bushing is used in a rotated mount, so why bother to say more?
i dont run slicks bags or any of that i did my runs on factory 18's and street tires. I bought the mounts because it was said they got rid of hop, and from my experience i hopped worse. this season i have a few things up my sleeve to help my issues
You're free to believe what you want to not gonna start an efight over it I'm just going by my experience with the ttr mounts and off of first hand problems i've heard with the ott mounts.
How am I being a dick? Look how many people buy ott mounts and still complain about wheel hop. No wonder I haven't tried them out. I'm just stating a trend, I never said your products are **** or worthless I'm just speaking from my personal experience and learning from others first hand experiences. No need to come in and call me a dick because your product still hops. I'm not going to get in a pissing match about it, it is what it is.
anyone have any experience with these?
NEW! Turbo Tech Racing STOP Transmission Mounts Chevrolet Cobalt 2005-10 (F35 Trans) ON-SALE! - Turbo Tech Racing, LLC
I was thinking about them even in a stock form to help with getting the power to stay on the ground... and eventually with the GMS1 and a slight intake mod...
worth it? yes or no
worth it? yes or no
something else that makes me lol......ttr mounts are suppose to rotate the engine like the powell mounts correct? so their engine mount is a stock replacement with a poly bushing correct? well the engine mount is limiting the rotation therefore=failure of some product down the road.
basically a rotated mount will help reduce power hop. It wont eleiminate it at the drag strip. The TTR mounts use a poly insert which creates a lot of vibration you may not like. The Powell mounts or OTT (same thing save the insert) have less vibration. Its up to you how much vibration you can handle. The solid racing mounts we made for all the Grand Am race cobalts vibrated awful. (see the GMR build book) It didnt matter for a race car. You may find it a different story on the street.
quoting qwikredline "wtf do you know you don't have them"
i have YOUR mounts not the one offs from the other guys they were your original ones that i paid alot of money for so if my cv joints are in misalignment "still" then what do you suppose is causing that? hmm
then again... I may be looking for something that's truly not needed though.. I mean hell, this car is the fastest in its class (in the world) at the nurburghring for a reason... maybe I should be satisfied with what I have too hahaha
Thanks for the reply.. lots of fighting for what?? haha.. I think the biggest thing I am looking for is a setup that will be good not only for straight line runs but more for autocross type of driving... so I am looking for the best "all around" mount...
Can I get some ACTUAL info with these?
Pros an cons?
basically heres what i have gathered and after this i will be out of this thread..
powell mounts
good source of helping with wheel hop(some have problems some dont)
better design and craftmanship
lighter weight
original design
billet aluminum
puts the axles in the correct alignment
only cons i have seen are some people still have issues with wheel hop.
ttr mounts.....
polyurethane bushing(thats a negative in my book but to some its not)
apparently rotates the engine
- if they do however rotate the engine i didnt notice where as my powell mounts are noticeable.... But i dont recommend using and sort of rotated mount with their upper mount as it is a replacement for the stock mount. rotated engine mounts with a upper mount that keep the motor firmly is place is going to cause unwanted stress elseware.
- copy
- overall the construction doesnt seem to be bad BUT i dont know what they are made out of.
theres a thread on these too...ill find the link.
powell mounts
lighter weight
original design
billet aluminum
ttr mounts.....
- copy
out of curiousity this is a question for john. Were the mounts designed on a car that was on factory springs? if so being lowered could cause the cv shafts to not be aligned as well? Just trying to find some insight to my hop issue
so again before you start being a dick head keep your snooty little comments to yourself.
Nothing biased, that's funny. OP being the sour manufacturer kinda seems biased from the beginning. Not to mention breaking things that don't matter and raising it up like it's important. Claiming vibrations out the yang when there are virtually none. Still having wheel hop after touting elimination. Whatever this community is a bunch of nutswingers to a name. I'll buy the best parts you can continue to buy into a name to try and be cool on the internet though.
i would love to see a comparison for the ttr sway bar vs ottp/powell hardcore and or street bars. ive had both on my car and it says enough what i have stuck with due to one causing me snap oversteer and after seeing multiple cars on here with a warped bar? hmmm. needless to say why it was pulled from their production line(as far as i know)
I never said ttr had a better sway bar. I said I buy the parts I feel are the best available. Whereof there is plenty of proof that prs has the superior product in that department. If I wanted to buy a rear sway I would get that. But I don't see how bringing a sway bar correlates to rotated mounts.
It's understandable for sure I'd be mad too, but I feel as if they did it better and there's no need to come into threads and single people out as dicks and spread misinformation because of it. Personally like I said I have virtually no vibrations/wheelhop. I have never ran prs rotated mounts no, but I felt it was unnecessary to try after multiple sources whose opinions I hold over anyones, brought prs mounts to the table as still having wheelhop, while ttr's did not.
I'm just tired of people riding the blind sheep bandwagon and not forming their own opinions, but pushing a product because of a name anyways. It's whatever though.
well it all depends on what your doing with the car too....road coarse and on the street i have no wheel hop....but i guarentee if i took my 442whp(ass hurt mustang dyno) car to a drag strip i would get some. i dont think the mounts were designed for a drag strip seeing as i know them mostly for road coarse use.
the sway bar thing was me speaking aloud because i hate people saying im a nut swinger without knowing me or my car. ive done plenty of research and development on my lnf...springs, coilovers, struts, turbos, sway bars. ive found numerous things that just do not work well for the lnf car. i know on lsj's and redlines there are things that just dont like the lnf car. so i have every bit of reason behind the products i choose....im not calling you a ttr nuthugger because you like their mounts now am i?
i use to have the powell raceshop supporters logo under my olllllld name..... good reason behind it too. none the less my old name was banned for making constructive critiscm twords this site and apparently they didnt like what i or a bunch of others had to say so none the less i deleted my turbo build along with a ton of other information i had courtsey of a mod on here and i keep all of that elseware.
n20saturn
Sep 30, 2015 12:26 AM
