UNI filter, intake dimensions
Old Feb 25, 2009 | 10:36 AM
usnsdoc's Avatar
Anyone out there using a UNI filter intake filter?
Anybody know off hand the size of the intake tube and the filter element? I.D., O.D.?
Old Feb 25, 2009 | 10:41 AM
Terminator2's Avatar
For a TC cobalt?
Old Feb 25, 2009 | 10:53 AM
usnsdoc's Avatar
yep, thats why I put it in the LNF section
Old Feb 25, 2009 | 10:56 AM
Oh, I did not know they made a filter for the TC. That is why I asked. Is it a stock air box replacement element or for an intake?
Old Feb 25, 2009 | 11:04 AM
usnsdoc's Avatar
They don't, but they have universal clamp on filters. So i was wondering if anyone had tried it out. I asked so if anyone had tried it i could get the measurements, rather than having to drive 45 min to my storage bay and measure
Old Feb 25, 2009 | 11:25 AM
If you have an aftermarket intake you need just measure the OD of it and you need a filter with at inlet size and no longer than 6" usually, and no larger than 5" diameter overall.
Old Feb 25, 2009 | 12:11 PM
usnsdoc's Avatar
Ok, Im looking for the STOCK ID and OD intake tube measurements where the intake meets the air box.
Old Feb 25, 2009 | 12:42 PM
Are you going to take a hacksaw to the plastic intake tube and put a cone filter on there? I believe the plastic tube is 3" outer diameter.
Old Feb 25, 2009 | 12:53 PM
usnsdoc's Avatar
wow, totally forgot how the intake was setup til i found a picture. duhhhh
Old Feb 25, 2009 | 12:56 PM
I too thought abot doing a hack job on the stock intake but because of the MAF sensor there really is not enough room to cut and put a new cone filter on the end.
Old Feb 25, 2009 | 03:40 PM
1WhiteSSTC's Avatar
FYI, DIY intakes for the ss/tc will result in CEL's, all the intakes released for the ss/tc were specifically flow tested ect ect so it wouldn't change the MAF sensor readings and would operate normally until tuned.
Old Feb 25, 2009 | 08:29 PM
usnsdoc's Avatar
Before anyone else posts replies. I thought the intake tube connected right at the airbox. The plan was to simply put a filter on. I realize a custom intake will cause a CEL. Hense, why I asked for the dimensions of the intake tube. Since we got all of that cleared up. NM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
