Update to engine noise.
Old Sep 28, 2009 | 11:32 AM
cmiller8006's Avatar
For those who was following the engine noise I was having. We thought it was a broken lifter, but after we took it apart and finally got a look, it ended up being a broken roller follower. Good thing it didnt come completly apart and take out my cam. Here is a couple pics.
Old Sep 28, 2009 | 11:37 AM
revhigh18's Avatar
hmmmm how many miles are on your car?
Old Sep 28, 2009 | 12:05 PM
weiss27md's Avatar
I have ticking too but I'm assuming that it is the direct injection. I heard it's normal for our cars to almost sound like it's a diesel.
Old Sep 28, 2009 | 12:24 PM
MoePwR's Avatar
i think i have the same problem. how hard was that to get out?
because i have this clatter that gets faster when i increase the rpms and i can hear it inside while im driving
Old Sep 28, 2009 | 01:13 PM
platinumrims's Avatar
looks like it wouldn't have taken much more to come apart... lucky lol.
Old Sep 28, 2009 | 02:03 PM
jb09ss's Avatar
What was your red line?
Old Sep 28, 2009 | 02:09 PM
Mike08ss/tc's Avatar
like moepwer said. did your noise increase also when the rpms went up. i have noticed this ever since i bought my car. i know that the direct injection plays a big part.
Old Sep 28, 2009 | 02:17 PM
HB_SS/TC's Avatar
You're lucky when they opened mine up my rocker arms weren't where they were supposed to be. lol
Old Sep 28, 2009 | 02:22 PM
eaglegsw14's Avatar
i had a second tick (other than the direct injection, it was very distinct) and it was my floaters.
Old Sep 28, 2009 | 03:34 PM
RYRO14's Avatar
ANY CELs?
Old Sep 28, 2009 | 03:51 PM
When the noise started it was just over 12000 miles.
Definitly got faster with rpms, however did not get louder, and was barley noticable in the cab. Only took about 3 hours total, but to do it in that time you need special tools from a GM shop that holds the cams and holds the timing chain so it dont fall into the motor. I wish I would of took more pics, but we got going and I didnt even think about it.
No it wouldnt, took the pin out and looked at the bearings and they were all worn down, so probably wouldnt be much longer before it came apart.
Redline was 7000, but I have dropped it down to 6700. Which sucks because now I have to hit fourth at the track lol.
Ummm, yea that aint good.
Last edited by cmiller8006; Sep 28, 2009 at 03:51 PM. Reason: Automerged Doublepost
Old Sep 28, 2009 | 03:54 PM
Stamina's Avatar
Interesting. I've been hearing something like a second tick coming from behind where the manifold meets the engine, on the side opposite of the fuel regulator. I'm worried it might be something like this now. I'll have to keep an eye on it now.
Old Sep 28, 2009 | 03:58 PM
Originally Posted by RYRO14
ANY CELs?
No CEL's, that is do to having dual valves. If it was a single valve there would have been.
Mine was on the exhaust cam side, the fathest one toward the drivers side. But I guess it can happen anywhere.
Last edited by cmiller8006; Sep 28, 2009 at 03:58 PM. Reason: Automerged Doublepost
Old Sep 28, 2009 | 04:01 PM
Stamina's Avatar
Yeah, this one's at the front, passenger side. Well I guess I can be slightly comforted, but still wondering about it. I wonder too if it could be related to the cam driven fuel pump. I'm not sure if that would create a noise someplace other than the fuel regulator area.
Old Sep 28, 2009 | 04:11 PM
Yea I am still trying to figure out what caused my problem. My buddie thinks it was a defect and would have happened no matter what, which I agree. But my brother thinks that either the valve stuck at high rpms and smacked the roller, or that there is a weak spring on that valve.
Old Sep 28, 2009 | 04:17 PM
Stamina's Avatar
Well, if we're going to be opening up the engine, might as well upgrade things while we're in there...
I wonder how much better valve springs are for the LNF... I hear that's a good thing to look into anyway if you're planning on spinning 7k+ RPM (which I personally am not, but it wouldn't hurt to have better springs).
Old Sep 28, 2009 | 04:30 PM
I think ferra has springs for the TC, I think there also like 600.00 for the set.
Old Sep 28, 2009 | 04:31 PM
Stamina's Avatar
Ouch...
Old Sep 28, 2009 | 04:41 PM
Ouch...
Yep thats why I lowered the rev limiter.
Old Sep 28, 2009 | 04:44 PM
Stamina's Avatar
Colossal group buy anyone?
Old Sep 28, 2009 | 10:35 PM
how much did it cost do fix this. can we order those tools from the chevy dealer. i want to say that zzp has springs.
Old Sep 28, 2009 | 11:14 PM
Stamina's Avatar
Question
These? The question then is, will they work?
http://www.zzperformance.com/cobalt_...1009&catid=143
Old Sep 29, 2009 | 04:03 AM
mkriebs's Avatar
Any spring for any Ecotec will work. Same with valves. So, you can get some good deals on some decent springs. I have been thinking about building my head this winter... But I wouldn't mind saving up and doing it all when we can get cams, then i can do port/polish/cams/springs at once.
Old Sep 29, 2009 | 09:12 AM
I dont ever see anyone carrying any valves for our cars. is there a company that has some. i want to do this but i am not so familar with the LNFs. Bulit a LS2. how much harder would it be for our cars or would it be easier.
as far as i know that they willl work. i believe that -Matt has them. i could be wrong.(zzp matt)
Last edited by Mike08ss/tc; Sep 29, 2009 at 10:59 AM. Reason: Automerged Doublepost
Old Sep 29, 2009 | 09:46 AM
blackbird's Avatar
Not quite any valve for any Ecotec. If you use an exhaust valve specified for a naturally aspirated engine it may or may not be able to withstand the much higher combustion exhaust gas temps seen in a turbocharged application. That's why the stock LNF uses sodium-filled valve stems in order to help dissipate heat.
