Upgrading the in tank fuel pump
Im upgrading my in tank pump to an e85 walboro 400. Do i need a fpr or anything else to make this work?
And for those that dont know i am adding a lsj fuel rail with stock lsj injectors to the runners of my ttr intake manifold. Fuel system should be good for ~700hp. And if i ever do run out of fuel i can always get bigger injectors
I'll fix that either way payam. And either way i'll need a larger pump. Im hoping to have my issues fixed this weekend. If not then the first week of january. Im on vacation both weeks and will have time to poay with it
Would a return system be needed or beneficial? And how so? I know very little regarding fuel systems so the input is appreciated
I'd love to know that as well unless he plans on going standalone. Which hasn't been done on an lnf yet. It would be possible to maybe use the new lt1 pcm and combine the LT1 engine harness with the LNF one. That would be very beneficial. Possibly work as well. Using a v8 pcm to control 8 injectors.
Im using a devils own progressive controller. I think that its pretty similar to the one in zzp's 5th injector kitIf it doesnt work properly then i'll try a split second additional injector controller. I have the devils own from my 5th injector setup so i figured id try it first
Yes they look similar. They are nearly the same on the outside. The differences are in the electronics. Using our MAP based injector controller was already better than using a meth controller. More importantly, our switch to a MAF based unit improved the transition and tuning even more.
I didn't say it won't work. A meth controller will physically cycle the injector and add fuel to the intake charge. The downside is the accuracy and tune-ability.
Chris, why not try the new injectors they have on their site. It's pretty cheap too considering the price of other injectors on the market etc.
