V8THIS Big Power Solstice build tread.
#52
maybe you should look at the lnf injectors. they arent even close to your standard fuel injector and a standard fuel injector wont work in the location of the di injectors. not to mention the lnfs have a 3000psi capable rail and so forth.
v8this... i think you should do a whole lot more research into what your about to do to the head. the path of airflow really matters with a direct injection head. taking out the bump who knows how much it will matter but i think you should get a head ready and flow bench the thing as well to see if your going to cause any sort of issues.
you will without a doubt need 4 additional injectors, stronger high pressure pump, custom cams possibly with a 4th lobe on the fuel lobe, larger low pressure pump.
im sure you know this but just some food for thought.
#53
#54
Figured out why my meth wasnt working, pump crapped out on me, so i ordered the newer version of AEM's Meth Pump. its way more powerfull and provides better atomization. Here are some pictures of my setup, all nice and hidden. Currently installing the failsafe kit.
the old pump is on the right and the new pump is on the right.
failsafe flow sensor..
New pump installed
nice clean install..
dual 38mm turbosmart wastegates for the new twin scroll setup!
ligenfelter parts? yup, the only thing they make for our cars is a damn thermostat.
New pump installed
#55
#57
Haz l33t wheelz.
This will not be street drive able, if that is part of your goal.
Will you be doing any suspension modification? You are also going to need to stuff a whole lot more rubber under there to keep it on the road.
Look what the guys at ZZP have done, iirc they've pulled the most hp out of an LNF so far.
Good luck, the road is going to be difficult, and this is not the first overly ambitious thread I've seen pop up over here.
#58
They're only used in a few engines, and there isn't a huge demand for aftermarket parts. They would be extremely expensive to produce, just look at the aftermarket diesel injectors and most diesels have sold more engines/cars than GM has with the same injector as the LNF
#59
Ordered EFR9180 and zzp stage 2 cams today. Ordered the large Opel injectors too, The oversized supertech inconel and black nitrate coated valves are here. My sleeved block is here, my fluidampner crank pully is here. I'm getting excited!
#64
I'll be back on island in like 3 weeks. And I'll be starting on the twin scroll manifold and 4" downpipe. I still need to find an intercooler core to make a custom front mount. I need to take some measurements first.
#67
The crank I was planning on using was fRom eagle but they discontinued it. So now I'm exploring other options. I want to be able to eclipse 1000hp so I'd like to use an aftermarket forged or billet crank. I'm sure this won't be the only motor I build for this car so we will see how it works out. I might do a custom offset ground lnf crank to stroke it a little that's an option I'm exploring too but I'll need custom piston' s to keep the compression down. I wish we had e85 in Hawaii
#68
#70
Parts!
GOT A WHOLE BUNCH OF PARTS WHILE I WAS GONE!
THE TURBO IS HERE!!
BORG WARNER EFR9180 RATED FOR 600-1000HP, WE WILL SEE..
BOX OF STUF FROM ZZP, STAGE 2 CAMS, HEAD GASKET, INTAKE MANIFOLD GASKET, AND OVERSIZED OPEL INJECTORS.
I DECIDED TO TRY THE .5 MM OVERSIZED VALVES FROM SUPERTECH, I LIKED THE INCONEL EXHAUST VALVE OPTION AND I LIKED THE SHAVED DOWN STEM TO IMPROVE FLOW, I INTEND TO TRY THE 1MM FERREA VALVES AT SOME POINT WITH ANNOTHER HEAD TO SEE WHAT PERFORMS BETTER.
GOT MY INTERCEPTOR SCAN GAUGES IN. WENT WITH RED TO MATCH THE FACTORY GAUGES AND DUAL GAUGE SETUP TO KEEP ME INFORMED BETTER.
HERES A SHOT OF THE SLEEVED GEN2 BLOCK. I AM THINKING IM GOING TO SLEEVE THE GEN3 BLOCK INSTEAD. I WANT TO PUT IT TOGETHER NOW BUT I WANT TO DO IT RIGHT. ITS SUCH A STRUGGLE.
THE VIBRANT EXHAUST MANIFOLD FLANGE, IM NOT VERY IMPRESSED WITH THE QUALITY BUT IT WILL WORK.
STAINLESS COLLECTOR FLANGE, ITS A 2-2 DESIGN, IN GOING TO DRILL HOLES FOR THE WASTEGATE DUMPS JUST OFF THE FLANGE.
I KNOW MOST GUYS USE THE ATI DAMPNERS BUT ATI WONT MAKE ONE WITH THE POWER STEERING PULLY, SO IM USING THE FLUIDAMPR HARMONIC DAMPNER.
THE TURBO IS HERE!!
#72
Ive decided to get the gen3 block sleeved. Going to get a quote tomorrow. I want it to be sure the motor survives my intended abuse, plus the darton sleeves can be bored out to 90mm, that means 2.2l lnf undersqare for high revs.
I want it to be together and running now!!! Ahh
