Vacuum lines help!!!
Ok so im wrapping up my 08 hhr ss with zzp's s256et turbo upgrade and i have the mbc with it how do i plumb the boost control solenoid in with the lines from the manual boost controller that zzp provided
ok so here we go.
there is a vacuum line that goes from the intake manifold directly to the side port of the wastegate.
a vacuum line goes from the intake manifold to the inlet of the boost controller
a vacuum line goes from the outlet of the boost controller to the top port of the wastegate
ok so here we go.
I was under the impression that if you have a manual boost controller you don't need to run the boost control solenoid. All you need to do is have the solenoid plugged in to the harness but don't have any vac lines connected. Then just hook the mbc up normally like any other mbc.
