Vacuum lines help!!!
Old Aug 23, 2012 | 04:30 PM
S256hhrss's Avatar
Exclamation Vacuum lines help!!!
Ok so im wrapping up my 08 hhr ss with zzp's s256et turbo upgrade and i have the mbc with it how do i plumb the boost control solenoid in with the lines from the manual boost controller that zzp provided
Old Aug 23, 2012 | 04:36 PM
BLAZIN07SS's Avatar
I'm too JDM for you
mine came labeled. not by my car or i would help you out with it. let me see if it's visible in pictures
Old Aug 23, 2012 | 04:43 PM
S256hhrss's Avatar
Ok thanks zzp hasnt emailed me back all day
Old Aug 23, 2012 | 04:51 PM
BLAZIN07SS's Avatar
I'm too JDM for you
ok so here we go.
there is a vacuum line that goes from the intake manifold directly to the side port of the wastegate.
a vacuum line goes from the intake manifold to the inlet of the boost controller
a vacuum line goes from the outlet of the boost controller to the top port of the wastegate
Old Aug 23, 2012 | 05:00 PM
S256hhrss's Avatar
ok so here we go.
Blazin im going to work on the car in about an hour could you pm me your phone number if you dont mind i hear exactly what your saying but it seems odd is all
Old Aug 23, 2012 | 06:31 PM
Frogstofall's Avatar
I was under the impression that if you have a manual boost controller you don't need to run the boost control solenoid. All you need to do is have the solenoid plugged in to the harness but don't have any vac lines connected. Then just hook the mbc up normally like any other mbc.
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
