Walbro 255
Old Jan 27, 2011 | 06:34 PM
RYRO14's Avatar
Walbro 255
Does anyone know for certain if this fuel pump will fit the LNF from OTTP? I tried e-mailing them and got no response...
Walbro Fuel Pump - Over The Top Performance
Old Jan 27, 2011 | 06:37 PM
OneCOLDBIZL272's Avatar
yes it will. pumps in the tank are the same, slight mod is needed to hold it in place thou. nothing major. nothing that wouldnt take an extra 5mins,
Old Jan 27, 2011 | 06:38 PM
RYRO14's Avatar
Ok thanks man
Old Jan 27, 2011 | 07:01 PM
tom.g's Avatar
Are you going for some crazy power that the stock in-tank pump just can't supply?
Old Jan 27, 2011 | 09:22 PM
Malaclypse's Avatar
Pointless mod unless you know some fancy trick to upgrading the high pressure fuel system or are running secondary injectors in the intake runners.
Old Jan 27, 2011 | 09:25 PM
RYRO14's Avatar
My car was tuned for an E47 mix. The commanded fuel pressure was set at 2700 PSI and the car throw a P0087 low fuel pressure code and it leaned out and cracked 2 pistons because my in-tank fuel pump couldnt keep up. So not a pointless mod IMO.
Old Jan 30, 2011 | 04:44 PM
Might be over kill for you but you could run a setup like mine and run dual 255 walbros one in tank, And the sec inline. walbro makes 255 inline pumps too, their bout the same price as an intank pump. You need to run a brained feedline to do so thou.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Cptnslo
Sep 24, 2015 09:32 AM
jgarciarivera
23
Dec 11, 2007 04:24 PM
kobaltking2589
Jul 16, 2007 11:43 AM
