Is this a waste?
Old Sep 13, 2010 | 07:23 PM
Tgustafsonjr's Avatar
Is this a waste?
So my mods are in my signature. I really dont plan on doing any more except for lowering springs, trifecta tune, and maybe an aftermarket IC. I was going to start putting money into some head work i.e port and polish, rods, pistons, valves, and valve springs. I'm thinking about setting my boost to 25psi and moving my rev up to 7k. Do you guys think the stock rods,piston and so on.. could handle this as a daily driver? Or should I play it safe and do the head work.
Old Sep 13, 2010 | 07:37 PM
chitala383's Avatar
my engine is all stock and my trifecta tune boosts 23 psi and rev lim is set at 7k and no problems yet for more than 6 months. my car is my dd and i drive it like i stole it! haha. ive heard of guys boosting around 27+ with stock **** and not having a problem. u should be good my man.
Old Sep 13, 2010 | 07:42 PM
awesome thanks
Old Sep 13, 2010 | 07:51 PM
peachpuff's Avatar
Those mods will only make sense if you upgrade the turbo.
Old Sep 13, 2010 | 07:59 PM
FRSTGRDEDROPOUT's Avatar
Gm build book says the factory internals can handle up to 400 hp. The factory clutch and axles cant handle this much though.
And i've heard of factory IC side tanks blowing of at 25 psi. Stock bypass valves start to tear after high boost tunes too.
Old Sep 13, 2010 | 08:02 PM
Wangspeed's Avatar
The build book is for the LSJ (although the chassis and suspension parts certainly apply). The SS/TC axles are seriously beefy. Have you looked at them? Go compare them to a truck axle.
Old Sep 13, 2010 | 09:41 PM
Most trucks have (at least gm trucks) Have solid rear ends. So its hard to compare. CTS'v Have much bigger axle half shafts and so do the new camaros. And ive seen plenty of both break or shear on a stock cars.
red_wing_2121
Sep 25, 2021 01:41 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
Getaway_Driver
Sep 1, 2015 02:20 PM
BlackS/C
Nov 14, 2005 09:24 PM
