Water/meth pump startup
Old Aug 29, 2009 | 05:59 PM
hiltu's Avatar
Lightbulb Water/meth pump startup
I just wired up everything for my devils own DVC-30 kit. With the pumps power wired to a keyed ignition source as soon as i turn the car over, the pump starts making a noise like its injecting. Is this normal? im fearing that its injecting water/meth and that somethings wired wrong or defective. I have my starting point set at 10PSI and never turned the car on so it never saw a boost input.
Update, i removed the outlet tube and turned the car over, pump "started" up but no flow. removed the inlet tube and the pump had a slight suction. My check valve is upstream of the pump and i believe its that the pressure the pump is drawing isn't enough to lift the check valve. This sounds funny to me though. Should my pump be "idling"/making noise with no input/desire from the controller?
Old Aug 29, 2009 | 06:00 PM
hatrickstu's Avatar
its pretty simple man, take the nozzle out and just watch it.
DarrenGC
Dec 24, 2021 01:55 PM
nathan112i
Sep 30, 2015 07:12 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
roth
Sep 26, 2015 12:16 PM
