weird clutch problem
So I was at a stop light and some red neck in a truck was like 'lets go! On green' so I was like ok whatever, no one around, it'll be funny, quick 1st and 2nd pull.. Well I go to lay in to it.. Of course wheel spin, shift into second still spinning? Or so I thought, go into 3rd and here I finally notice its not spinning, just reving illike a spllipping clutch.. Which it was slipping but.. The part that gets me is.. There was no pressure in the clutch pedal.. So i let off and drove normal and now its working fine.. No slipping andthe pressure is still there.. I don't drive my car hard alot.. At all, have 31k miles, been tuned for about a month or so, i use nls every now n then when faces are to be raped lol in this case i was not using the nls
Just the car freaking out? Freak problem? This happen to anyone else? Hope I don't need a clutch
moneys tight at the moment... Poooo
You got punked by a redneck in a truck? It better have been a chevy lol. Jk.
It's wierd that you'd lose all pressure. I think your clutch and brakes run off the same fluid resivoir? Maybe check to make sure it has enough fluid.
