What to expect?
Old Sep 28, 2012 | 12:46 PM
esink's Avatar
What to expect?
Hey guys
currently I have a K&N SRI, a MPx turbo back exhaust & a forge BPV. I'm tuned for 93 octane and making 284/316.
I'm considering getting a full intercooler kit from pwerks, new MAP sensors as well as switching to E-47.
so basically I'd be full bolt ons with E-47. What should I expect from this?
Old Sep 28, 2012 | 01:24 PM
Balt_and_Vette's Avatar
Why are your numbers so low? I had almost the exact same numbers with gms1 and bolt ons on a dynojet that's known to be pretty accurate.
Old Sep 28, 2012 | 01:26 PM
TommyP's Avatar
AWD > FWD
it was probably a mustang dyno. Or he's running low boost
Old Sep 28, 2012 | 01:28 PM
BPacak's Avatar
Vtec Rep
i put 300hp on a mustang dyno with a trifecta tune haha.
Old Sep 28, 2012 | 01:31 PM
09BlueBaltSS's Avatar
^read sig
On the same dyno I'd expect around 320whp/350wtq. Bump it up to 24 psi and throw some timing at it.
Old Sep 28, 2012 | 01:53 PM
SSlobalt's Avatar
Originally Posted by esink
Hey guys
E47 will give you about a 10-12% increase in HP, if done correctly.
Old Sep 28, 2012 | 02:13 PM
esink's Avatar
It is a mustang dyno. On a dynojet I'd probably see something like ~310. I'm running 22PSI
Old Sep 28, 2012 | 03:35 PM
It all depends on how the dyno is set up. The whole mustang dyno being a low number reader is a croc of ****. You can get high reading mustang dynos as well. Like I said I laid down 281whp and 309 ftlbs on a "heart breaker" with full bolt-ons and gms1. Now with my 110/94 mix and hpt I put down 330whp and 374 ftlbs. Still timing left on the table so with a higher mix percentage I could go another 10-15 whp and probably over 400tg.
Old Sep 28, 2012 | 04:22 PM
09CobaltSS1's Avatar
Comparing dyno numbers from different dynos is barely even worth discussing or getting concerned about. It has been said time and time again yet always seems to get pushed under the rug, just stick to the same dyno and focus purely on gains made NOT what someone else put down on a different dyno in a different part of the country in different weather conditions and different correction facts. Plus depending on the dyno opperator different numbers can be made due to load/vehicle weight settings on the dyno. Also factor in guys making these HUGE torque and hp spikes with claiming these massive dyno numbers when realistically the graph looks like junk.
Old Sep 28, 2012 | 04:56 PM
Sox-Fan's Avatar
Got Brakes?
Originally Posted by 09cobaltss1
comparing dyno numbers from different dynos is barely even worth discussing or getting concerned about. It has been said time and time again yet always seems to get pushed under the rug, just stick to the same dyno and focus purely on gains made not what someone else put down on a different dyno in a different part of the country in different weather conditions and different correction facts. Plus depending on the dyno opperator different numbers can be made due to load/vehicle weight settings on the dyno. Also factor in guys making these huge torque and hp spikes with claiming these massive dyno numbers when realistically the graph looks like junk.
+1
Old Sep 30, 2012 | 02:19 PM
esink's Avatar
My graph is pretty smooth. A tune well done in my opinion.
Graph is current (284whp/316wtq)
Old Sep 30, 2012 | 03:01 PM
AARON-SS-TC's Avatar
350whp/410wtq @ 24psi...or somewhere around there
Old Sep 30, 2012 | 03:31 PM
^^ ehh considering his 93 numbers I would put him more in the 320-325whp/350-360wtrq range on this particular dyno. Plus anyone making 400+wtrq is usually only because of a massive boost/torque spike. It's nothing to be proud of in my eyes.
Old Sep 30, 2012 | 03:37 PM
DirtyBalt09's Avatar
Expect to need a new clutch soon.
Old Sep 30, 2012 | 03:56 PM
Sox-Fan's Avatar
Got Brakes?
That all depends upon how hard and fast the tuner ramps in the torque.
Oct 20, 2015 09:56 PM
bigdogstokes16
Oct 8, 2015 10:28 PM
The Rookie24
Sep 14, 2015 07:03 PM
Adam144
Sep 3, 2015 07:48 PM
